DAC and long cable run.
Using the 10k and .1 cap for the internal DAC and a long noisey cable run, if I use a .01 on the far end as well to knock some noise down, does that affect the voltage?
I can't test this at the moment but need to figure it out.
I'd rather use a .1 at the far end if having both .1's doesn't affect the output.
Post Edited (Originator) : 5/2/2008 7:16:20 AM GMT
*Peter*
The motor and motor driver will have some noise and I want to keep the Ref level as clean as possible. The line is only 6 feet.
how about placing the DAC as close as possible to the motorcontroller shielded with an aluminiumhousing ? And send the noise-insensitive frequency-signal along the 6feet-line?
What is the maximum changespeed of the Ref-Voltage ? If this changespeed is low you could use an OP-Amp as a voltagefollower with smoothing-capacitors on input- and outputside
Depending on your maximum changespeed the capacity could go up to 1000 uF
best regards
Stefan
