How can I make basic stamps by scratch?
I found a site that had a link to Parallax that showed how you can make your own BS2sx microcontroller by buying parts and placing them on a breadboard, making it much cheaper. The link doesn't work anymore, so I'm assuming when the website changed the link stopped working and it was never changed again. Does anybody·know where I can find the info on how to make the different microcontrollers?
Browse throught the product listings at:
http://www.parallax.com/Store/Microcontrollers/BASICStampOEM/tabid/135/CategoryID/10/List/0/SortField/0/Level/a/catpageindex/1/Default.aspx
and look at the various downloads they have available. You should be able to find most of the materials you would need.
Max Wooden
Reedley, California
If you are strapped for cash, you might be able to locate a 2nd hand BasicStamp here or on E-Bay. Many of us started with the BS2 and have upgraded to a faster version with more memory.
Considering all the free support material that you can download, it is still cheaper than anything else out there.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
·How you can make your own BS2sx microcontroller by buying parts and placing them on a breadboard, making it much cheaper.
I do not know why you would want to built your on boards when you buy them for $10.00 already made
Here are the Links to them
http://www.parallax.com/Store/Microcontrollers/SXDevelopmentBoards/tabid/141/CategoryID/54/List/0/SortField/0/Level/a/ProductID/399/Default.aspx
http://www.parallax.com/Store/Microcontrollers/SXDevelopmentBoards/tabid/141/CategoryID/54/List/0/SortField/0/Level/a/ProductID/362/Default.aspx
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/1/2008 11:22:24 AM GMT
Those are SX board. Not BS2sx boards.
They are still a great value and can be programmed with SX/B (BASIC for the SX).
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
You might find this a little annoying -- if so, let me point out that almost everything else Parallax sells is completely documented, with schematics, with part numbers, with tutorials for use, with help files, and with this very nice responsive forum for answering questions. Almost the ONLY thing they keep proprietary is the PBasic run-time program burned into their OEM chips.
Let me also point out, that as far as I can tell EVERY other small processor vendor has MORE proprietary stuff, costs more, and has less support, than Parallax. Note I don't work for Parallax, I've just been using their stuff since 2002 or so.
What is the diffrent the SX board and BS2sx boards as far as the Chips
This may seem as a Dump question but I have to ask
··Thanks for any·
Sam
The BS2sx is a BS2 running on an SX chip. As such, it uses the 'stock' BS2 hardware (IDE, BoardOfEducation (BOE), standard cable). And the OEM SX chip Parallax will sell you has the PBasic run-time environment burned into it. To 'complete' the BS2, you'll then need an external EEPROM, external brown out detector, a couple of external transistors and capacitors, and a 50 Mhz resonator.
The BS2sx runs much faster than a BS2, which is why people like it. An SX28 application with your own code burned into it runs EXTREMELY fast -- but is not as easy to program as a BS2sx.
If you'd like to build your own OEM Stamp like the BS2p40 then I can help! In order to do so you will need to buy an OEM BS2p40 OEM Basic Stamp chip from Parallax at:
www.parallax.com/Store/Microcontrollers/BASICStampOEM/tabid/135/CategoryID/10/List/0/SortField/0/Level/a/ProductID/19/Default.aspx
I have a PCB board that can be used as a carrier to mount this chip. By adding extra components you can build a complete module similar to the BS2p40 Stamp module. The main differences are that it uses a MAX232 for the serial interface and uses a through hole EEPROM and resonator. It is an early board I made that is similar to a module I designed for the SX48 chips:
http://forums.parallax.com/showthread.php?p=627108
It is slightly different in that it is a green PCB and lacks the silkscreen for the pin markings. At the moment I still have some of the blank boards left. They are $6.95 (plus shipping) and include instructions. It makes a great way to mount the BASIC OEM chips!
Remember, you'll need to get an OEM BS2p40 BASIC Stamp chip, through hole EEPROM, and through hole resonator directly from Parallax. By adding other parts you can make the complete module if you want.
If anyone needs one just send me a PM.
Robert
if your experiance led you to ask this question,you probably arent ready for the task,"no insult meant" but there are other cpu's like z80,6502,m6800,x86 wich are better documented and would be alot easier to build and augment besides the stamp. these things are designed to be unhackable, even though flaws and bugs do exist and it is through a flaw you inturupt a processor .
If you want to build your own BASIC Stamp we have made this quite easy by making the core components readily available. Prior to coming to Parallax I had integrated the BASIC Stamp into a few designs bringing the cost of having an embedded BASIC Stamp to under $15.00. If you’re interested in exploring this option I would suggest having a look at the OEM BASIC Stamps as they’re designed to show you what a BASIC Stamp is made of. If you have specific questions from there please follow up here and I will try to answer your questions. I hope this helps. Take care.
The 3.8V and 4.2V ratings are the voltage at which the system goes into reset. This is designed to protect the EEPROM from being corrupted by writing to it when it drops below the safe write voltage. The current version of the BS2sx OEM kit includes the 4.2V brownout detector. In theory you could use a 3.8V if you want in an OEM application since most EEPROM chips will run at lower voltages than when the BS2 was first designed.· Below is a link to the BS2sx OEM Kit.· I hope this helps.· Take care.
http://www.parallax.com/Store/Microcontrollers/BASICStampOEM/tabid/135/CategoryID/10/List/0/SortField/0/catpageindex/2/Level/a/ProductID/501/Default.aspx
