servo timer using BOE with stamp2
Hello. I'm new at this, but what I'm trying to do is use my board of education (with stamp2) to control a servo motor. I want to be able to control how fast it goes back and forth (ie 30 Hz, or 60 Hz, or something along those lines).
I believe Parallax's 'servo controller' has a ramp function that does something like this, but I was wondering if I could just write code for stamp to do the same thing.
I realize this is a very basic project, but I can't seem to find any examples of it on the net.
-Kyle
-Kyle
You have to put out a servo control pulse about every 20ms. Normally this is done with a FOR / NEXT loop. All you have to do is to increase (or decrease) the width of the servo pulse a little bit every 20ms until it reaches the position you want. The number of times through the loop determines how long the ramp takes (in 20ms increments).
Start:
FOR i=1 TO 30
PULSOUT 15, 500
PAUSE 20
NEXT
FOR i=1 TO 30
PULSOUT 15, 1000
PAUSE 20
NEXT
GOTO start
Is there a way to change that so that I'm not using the i counter, but instead it changes direction once the servo actually reaches the given position? This is probably a pretty silly question, but does the servo send positional information back to the stamp?
Realistically, there's no way for the Stamp to be able to find out when the servo reaches the desired position. I think it was Paul Baker who did some experimenting with servos where the motor was "starved" for power and the Stamp would watch how much current was drawn as the control pulse width was changed. At the control pulse width corresponding to the current servo position, the current drawn would drop. This could provide position feedback.
for your variation of the speed you could use something like:
FOR i = 500 TO 1500 STEP 10 'look here that I use the STEP to make the change faster
PULSOUT 15,i 'and here I use a VARiable to send the pulse lengh
PAUSE 20
NEXT
I'm thinking that you are using a regular continuous rotatior servo, what did you mean by variating 30Hz to 60Hz ???
Amaral
For Hertz I just mean the frequency that it oscillates at.. 30 to 60 Hz would be ridiculously fast.. but more like 0.5 or something. So the servo would oscillate 0.5 times per second.
And it is just a normal hobby servo. I haven't modified it in any way.. its range is limited to about 180 degrees etc.
For that you can assume that the servo will go to the "ASKED" position, and untill this is not there it will keep trying (until is been asked) ! ( from the BS to the servo you have an open loop, but from the servo to the shaft it is a closed loop)
There's no way for the servo to send an information that it reaches the destination , you will have to guess by the time that you are requesting it ! what kind of load are you moving with this servo ( or thinking in moving) ?
Amaral
