Has Any One Used An Solder Rework Station with an Internal Vacum Pump
Here is the Link To the one that·I bought
Any and all feed Back are·welcome
http://www.mpja.com/prodinfo.asp?number=17204+TL
··Thanks for any·
·that you may have and all of your time finding them
Sam
··Thanks for any·
![idea.gif](http://forums.parallax.com/images/smilies/idea.gif)
Sam
I did some PCB repair for a company a few years ago, and we used vacuum desoldering units. They were not as nice as the one you pictured, but they did work well most of the time.
I would suggest you handle the "gun" very carefully. We had one go bad, and the tip became energized, it killed every chip we used to remove with it. The heater unit in the handle had shorted out to the tip, and was giving all the chips AC. We didn't know until it was too late that the tip was "hot". It cost a fortune to fix that little mistake. We were repairing boards that were un-attainable.
It should be said, the guys in the shop were pretty rough on equipment.
Looks like a very nice unit,
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
1. Always keep the tip cleaned out for maximum suction.
2. When unsoldering a lead, wiggle the lead slightly once the solder is melted and while sucking out the solder. This will help to free it.
3. Don't leave any lead or pad heated up for too long. It's easy for pads to delaminate from the board if you do.
4. Sometimes you may have to add solder to a connection you want to desolder in order to "prime the pump".
5. Don't throw away your solder wick just because you've got the pump. It will still come in handy occasionally.
I would suggest you handle the "gun" very carefully. We had one go bad, and the tip became energized, it killed every chip we used to remove with it. The heater unit in the handle had shorted out to the tip, and was giving all the chips AC.·
Thank You for letting me know that
Phil
Thank You For these pointer on how to use one
··Thanks for any·
Sam
-- Keep tinned on the ring at the tip so that it makes good contact. Buy a tinning block, available atRat Shack too.
-- Clean the tip by keeping a piece of stainless steel wire handy just a little less than the inside diameter of the tip. Sometimes pieces of solder get stuck in there, and then things get worse as the air flow is restricted. If it gets really clogged up, then it is a royal PITA to clean it, and if that happens you will have to take off the tip and then a focused heat gun on the barrel can help a lot. Better to keep it clean incrementally.
-- The above is especially true when using lead free solder which has a higher melt temperature and a knack for glomming up the works.
-- Learn to hold it up near your ear and learn what it sounds like when the air flow is good, and clean it if it sounds constricted.
-- Take the tip off occasionally to keep it from corroding in place.
-- Clean the interior frequently to remove the accumulated solder. Wash your hands--it's a dirty business!
-- Gravity can be your friend, to help solder fall down.
-- Use a heat gun to heat set on gentle air flow to heat up the entire workpiece to 140 to 150 degrees C, and that preheat will help the desoldering tool. Especially important with leadfree. It alleviates overheating heating a pad at one spot.
-- If you are designing a PCB with through-holes, leave generous space around the pins and wires. It is very hard to desolder pins that are jammed into holes with little to no clearance.
Tracy Allen
www.emesystems.com
Yes!! This a very good point that deserves extra emphasis!
Thank You for your reply and ALL·OF THE INFO··· ·
And all of the GOOD
··Thanks for any·
Sam
Rick
· It look like it is made for mpja
Are the consumable parts, filters, tips, and heating elements really available? How much do they cost? (no prices for those on mpja website)
·These parts·I also order filters, tips and cleaning rods
This at the ·bottom of the Page there those parts and the prices
filters, tips and cleaning rods·all of the parts in green i also order
If you want to find all the parts just change the 17213+TL to the part # you are looking for
http://www.mpja.com/prodinfo.asp?number=17213+TL·Cleaning Wire for 1mm Tip
http://www.mpja.com/prodinfo.asp?number=17209+TL· Heater
Replacement parts Available:
17208-TL: Handle/hose assembly
17209-TL Heater
17205-TL: 1mm tip
17206-TL: 0.8mm tip
17207-TL: 1.3mm tip
17210-TL: Small Solder Filter for Handle
17211-TL: Larger Filter for Base Unit
17212-TL: Cleaning Wire for 0.8mm Tip
17213-TL: Cleaning Wire for 1mm Tip
17214-TL: Cleaning Wire for 1.3mm Tip
The temp controller works very well and the pump seem to have enough power for what
I was doing with it tonight·( removing leds from an low voltage yard lights power board here is the link to them·http://www.doctorled.com/p11.htm )·as far as how well it will hold up i do not know that yet
I have a 137·ESD·soldering station that i have had for 3 years the controller went bad so i had to buy a· new one and will see if could repair the old one
Here is the Link to it
http://www.howardelectronics.com/xytronic/137ESD.html
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/1/2008 11:39:45 AM GMT
This has the best thing ·that you gave me on this
This seem to happen when there is a lot of solder on the board where I want to remove a compoant
Now i tryed to set the temp at 700 * F this seem to help but dose not keep it from happing
I do not want to go much higher than this because of burning up boards
This very true
I like this Desoldering Station alot·
I know love parts of it and hate parts of it but what can you say
··Thanks for any·
Sam
Another thing I do (unconciously) to keep the tip from clogging is to tilt the handle (tip up) and hit the vacuum again to pull the molten solder down into the holding container.
Thank You for your reply and the tips I will try this and keep these thing
in mind when i using it
The most common mistake I see is bearing down on the joint too hard and tearing up foils and just plain leaving the tip on too long. If you don't get a component completely desoldered then resolder it and try again. It's much harder to desolder something that is half desoldered.
··Thanks for any·
Sam
