Cannot get the AEROCOMM AC4490-200M module to work with propeller!!!
HI,
Has anyone got WORKING code to communicate with the AEROCOMM AC4490-200 Modem module.
I can't get anything thing to work, its very frustrating!!!
I have looked at ALIBI's stuff but no success. the code that he has on his website is too cryptic for me to understand.
There is very little on AEROCOMM's website to help, in fact there is very little info ANYWHERE regarding this modem, I believe I have chosen the wrong kind of RF 900Mhz Modem.
I am (at least) trying to get to the "settings mode" so I can set the addresses , channel etc
I have tried to send a string AT+++ to the modem and then trying to receive the response back into a string pointer so I can at least display this info on my LCD.
I have tried swapping RX & TX around etc
Attached is my current circuit for the prop.
Thanks to anyone that can help me.
regards
Dave M
regards
Dave M
http://forums.parallax.com/attachment.php?attachmentid=49347 PropCOMM
While it isn't a solution, it may help you troubleshoot.
Change the TX/RX pins as required.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Tx - Rx
Rx - Tx
Rts - Cts
Cts - Rts
thanks for the replies.
So , is my circuit correct?
There's no point getting any code to work if my circuit is wrong.
Has anyone got this working?
Dave M
I am also leary about connecting LED's directly to signal lines without buffering.
Cheers
I am aware of that, I disconnect the prop plug when I restart my device.
Aerocomm have said that connecting LEDS should not be a problem.
Dave M
I have it working with the PROP now!!!
I reversed the transmit & receive pins ( in code ) I had them wrong!
I was transmit & receive routines were incoorect, now they seem to work.
I also got the modem working with the PC via the configuration software, They had a default setting for hardware handshaking set to ON , So I turned it off
thanks
Dave M
