Wireless XBee Sensors Just Won't Work!
I've tried everything I can think of and read the syntax manual, conversion tips, and application notes more times that I can count.
The sensor node is sensing the value properly.· I don't know if it's actually sending the data through the AppBee or not.· All I can tell is that the TX LED on the sensor module is blinking when it should, which leads me to believe it's sending the data.
'·· {$STAMP BS1}
'·· {$PBASIC 1.0}
[noparse][[/noparse] I/O Definitions ]
SYMBOL· Ping··········· = 7
SYMBOL· TX············· = 2
SYMBOL· RX············· = 0
SYMBOL· SLP············ = 4
SYMBOL· RTS············ = 6
[noparse][[/noparse] Constants ]
SYMBOL· Trigger········ = 1···················· ' 10 uS trigger pulse
SYMBOL· Scale·········· = 10··················· ' raw x 10.00 = uS
SYMBOL· RawToIn········ = 889·················· ' 1 / 73.746 (with **)
SYMBOL· IsHigh········· = 1···················· ' for PULSOUT
SYMBOL· IsLow·········· = 0
[noparse][[/noparse] Variables ]
SYMBOL· rawDist········ = W3··················· ' raw measurement
SYMBOL· inches········· = W4··················· ' inches conversion
[noparse][[/noparse] Program Code ]
Main:
· PAUSE 2000
· HIGH SLP······ ' Put XBee to sleep
'· SLEEP 15······· ' Put Stamp to sleep for approx 15 seconds
· GOSUB Get_Sonar······························ ' get sensor value
· inches = rawDist ** RawToIn·················· ' convert to inches
· DEBUG CLS···································· ' report
· DEBUG "Time (uS)..... ", #rawDist, CR
· DEBUG "Inches........ ", #inches, CR
'· IF inches > 22 OR inches < 2 THEN Main
· LOW SLP···················· ' Wake XBee
· PAUSE 10··················· ' Give XBee time to stretch and yawn
· SEROUT TX, T2400, (#1, 13)·· ' Transmit notifier
· PAUSE 10
· GOTO MAIN
END
[noparse][[/noparse] Subroutine ]
Get_Sonar:
· LOW Ping····································· ' make trigger 0-1-0
· PULSOUT Ping, Trigger························ ' activate sensor
· PULSIN· Ping, IsHigh, rawDist················ ' measure echo pulse
· rawDist = rawDist * Scale···················· ' convert to uS
· rawDist = rawDist / 2························ ' remove return trip
· RETURN
The receiver module just flat out doesn't work, and I have no idea how to make it.· It has to sense the value coming from the sensor node, but it doesn't.· I assume it's just staying at the SERIN command.
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL· RX· = 2 ' Receive Pin
SYMBOL· TX· = 0 ' Transmit Pin
SYMBOL· In· = B3
HIGH TX
Main:
· SERIN RX, T2400, In· ' Accept and view as character
· DEBUG "RECEIVED", CR
· GOTO Main
· END
I configured the XBees with different MY addresses, receiver as 0 and sensor as 1, set the receiver's destination address to 0 and FFFF (neither worked), set the sensor's destination to DL = 0, and set the baud rate to 2400 on both.
Any ideas might help, I'm completely at my wits end and I have no idea what to do.· I've been trying to make this work for entirely too long now.
Thanks.
'·· {$STAMP BS1}
'·· {$PBASIC 1.0}
Main:
· PAUSE 2000
· PAUSE 10
· GOTO MAIN
END
Get_Sonar:
· RETURN
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL· In· = B3
HIGH TX
Main:
· GOTO Main
· END
Thanks.
along the lines of what you're trying. If you would like, I'll keep you advised as to my progress (or lack thereof)
If you have questions about XBees in your own project, though, please post them (preferably in a new thread).
