Since the transceivers are really just a wireless serial device you can simply use the Full Duplex Serial object for communication. Of course, in any RF application it’s always a good idea to do some packet checking to make sure everything arrives where it should. If that if necessary in your application you can handle that outside of the serial object. Take care.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Here's a link to the device I'm refering to:
http://www.parallax.com/Store/Accessories/Communication/tabid/161/CategoryID/36/List/0/Level/a/ProductID/440/Default.aspx?SortField=ProductName%2cProductName
Shmow
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Steve Norris at Norris Labs has successfully interfaced a Propeller to the 912MHz transreceiver.
Download and review the Propeller spin code at the following link:
http://www.norrislabs.com/Projects/RoboCam/index.html
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edited (Tom C) : 4/29/2008 3:39:51 AM GMT
