BS2 + MSRS Computer Controlled Tank
Still in progress, but here is the MSRS code that brings up a BoeBot, BoeBot Drive, I/O control , and Simple Dashboard.
To use this,
make a backup copy of your Samples folder in:
C:\Microsoft Robotics Studio (1.5)\samples
Copy the contents of the Misc.zip file to your Misc folder·under samples.
Copy the contents of the Platforms.zip file to your Platforms folder under samples.
plug the servo motors into ports 12 and 13
change the serial port to whatever your system is using
It is based upon the samples provided by Microsoft. I am NOT a software person and still don't understand how the system works.·I post questions to the MSRS forum and usually get an answer within 24 hours. Here is the link.
http://forums.microsoft.com/MSDN/default.aspx?ForumGroupID=383&SiteID=1
To use this,
