ZigBee amd BS2P
I have two BS2's each loaded with a ZigBee transceiver and they work perfectly. However when I swapped one of the BS2's for a BS2P(which is the Stamp that I ultimately want to use for the project) and made the appropiate changes to the Directive and the Baud rate as per the Parallax Reference Manual I don"t get any communication between the original BS2 and the new BS2P. Beside the Baud rate is there any other changes I need to make to get the BS2 to communicate with the BS2P via the ZigBees? This should be a good one for Mike Green. Thanks in advance for any help,
Danny22
Danny22
