alternative serial port connection
I will be using a MAX3235 in place of the discrete circuit show in Figure 2.3.2 on page 5 of the Prop Datasheet.
I see that the DTR line (pin 4 of the DB9) to the prop's RESn line has a pull-up resistor in it.
Will the pull-up resistor and the 0.1uF cap still be required with the MAX3235 chip?
