TTS
im looking for a chip/circuit that can handle a simple TTS from my BS2. i want my bot to talk.
I have it setup via the eb500 bluetooth module now, so i can scroll anyting i type accross the lcd module on the bot. But as i said, i want it to talk.
anything less expensive?
Cheaper alternatives would probably involve even more work. There has been some good work with the Propeller on voice synthesis and you could use a Propeller Protoboard with a couple of components for a DAC and an audio amplifier like the LM386. You could also use a ChipCorder audio recorder chip to store some "canned" phrases that you could play back on demand to seem like speech synthesis. Again, you'd have to "roll your own", but these are a bit easier to use than the TTS chip.
Post Edited (Mike Green) : 4/27/2008 11:36:58 PM GMT
