Navigational System Project using Trilateration
I'm trying to implement a navigational system using trilateration. I plan on using 4 stationary RF transmitters to send a continuous signal to 4 RF receivers connected to a Javelin Basic Stamp. But I'm not sure how I will be able to determine the time (T) of transmission and reception used to calculate the distance between the transmitter·and·receiver.
I understand that distance (d) is measured by multiplying the speed (c) of the Radio Wave times the time (T) it takes to send the signal [noparse][[/noparse]d = (c)(T)]. If the speed is to remain constant, this means that the time of transmission will vary, thus determining the distance between the two at a given moment in time. Trying to capture that time (T) is my dilemma. I’m not sure if this is possible with one-way-only RF transmission, but if so any help would be greatly appreciated.
- Stephen
"Trying to capture that time (T) is my dilemma. "
Yes, it is. If you're talking about locating down to just a couple of feet using transmitters located within a reasonable distance (< a mile?) of the object you're trying to locate, the difference in time is going to be pretty miniscule. That means you're going to have to have a device capable of measuring some very short intervals. GPS works in part because the devices are capable of measuring time very precisely, and partly because the transmitters are located somewhere around 10,000 miles away from the receivers.
By my early morning figuring, let's say your device were right next to one of the transmitters, and a mile from another one. The time difference for the signals would be .019 seconds. That's measurable, but we're talking about a big baseline and the best case. Let's suppose you're putting the transmitters just 1/10th of a mile from the device you're tracking. Then the best case time difference is .0019 seconds. You're probably thinking about having the transmitters 50 feet or less from the device you're tracking: at 50 ft, best case difference is about .0002 seconds, or about 1/5000th of a second.
Now, that's best case, so if your hardware can just barely detect 1/5000th of a second differences then with your transmitters located 50 feet apart you're going to have 50 foot resolution.
On top of that, you need a clear line-of-sight so that the signals aren't being received after reflecting off of other objects (which will of course change their travel time and mess up your calculations).
Post Edited (sylvie369) : 4/26/2008 11:44:05 AM GMT
So then, with that in mind, would be easier to synchronize all of the transmitters and determine object orientation by measure the 'Time-Difference-of-Arrival' (Multilateration)?
Found this:
http://video.google.com/videosearch?q=robot+swarm&sitesearch=&start=10
- Stephen
Post Edited (Franklin) : 4/26/2008 6:26:15 PM GMT
Take this all with a grain of salt: I haven't ever done any of this, or even tried it. There may be some nice trick that everyone except for me knows about.
For 20 ft range ultrasonics is the way to go.
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
http://www.utaharc.org/rptr/ark_df_desc.html
"The circuits described on this page are of the "Homing" or "TDOA" type in that they switch two antennas rapidly and, by observing phase changes in the incoming RF signal, allow the user to determine the bearing of the transmitter"
It's going to be a lot more complicated than just reading off some timing numbers and doing some math, but it might do what you want to do.
