music to led
I want to try to measue if an audio signal has a high or low by using the basic stanm board and if it is high I want the light to come on and If it is a low I want the light to stay off.·
does any one know how to set up the program
What are you trying to measure, again?
It's possible through using a·diode, capacitor, and resistor to create· a signal sensitive to the average sound volume, would this work for you?
Here's one example of a simple sound detector using a microphone: www.seattlerobotics.org/encoder/200003/larryb.html
