The "Black Art" of choosing bypass capacitors
Ever wondered whether the bypass capacitor you've chosen is adequate for your application, or always choose the same value but would like to know the science behind it so that you can use the minimum value needed in your design to reduce production cost? Here's an article that explains what you need to know to make an informed decision on your bypass caps: http://www.edn.com/contents/images/454638.pdf
Paul Baker
Paul Baker
I'd just go for 0.47uF for all the bypass caps so I don't have to stock so many values.
www.fd.com.my
www.mercedes.com.my
Paul Baker
After the "touchdown" to zero ohms, the impedance seems to increase again with frequency.
This goes against the formula for impedance calculation Z = 2pi C/F ( something to that effect ).
Why is that so?
www.fd.com.my
www.mercedes.com.my
The graph is perfectly normal
Impedance, Z = √ (R^2 + X^2)
Where:
R = Resistance
X = Reactance
Total Reactance, X = XL - XC
Where:
XL = Inductive reactance
XC = Capacitive reactance
Inductive reactance, XL = 2pifL
Where:
f = frequency in hertz
L = inductance in henrys
Capacitive reactance, XC = 1 / 2pifC
Where:
C = capacitance in Farads
Note: The reactance is capacitive if the input frequency is above the frequency pole. (HIGH PASS FILTER)
The reactance is inductive if the input frequency is below the frequency pole. (LOW PASS FILTER)
Beau Schwabe
IC Layout Engineer
What about multilayer capacitors, would the frequency response be about the same as ceramic capacitors?
www.fd.com.my
www.mercedes.com.my
A Baker's Dozen: Real Analog Solutions for Digital Designers (Paperback)
by Bonnie Baker (Author) "
www.amazon.com/Bakers-Dozen-Solutions-Digital-Designers/dp/0750678194
Aka: CosmicBob
Michael Park
PS, BTW, and FYI:
To search the forum, use search.parallax.com (do not use the Search button).
Check out the Propeller Wiki: propeller.wikispaces.com/
In principle, the by-pass capacitor is just a special case of using a capacitor as a low-pass filter.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
