General FET Question.
Good morning,
I am·driving the Gate of·a 2n7000 N-Channel FET via a 5V output pin. Someone on the Forum told me that I should pull the gate down via a resistor because the gate of a FET acts like a capacitor. Could someone give me a correct value for this resistor, would a 1K be sufficient. My circuit will be installed in a noisy electrical environment.
JMLStamp2p
JMLStamp2p
Back to your question. I don't know what your 5V output is from, but like I said, if it can source and sink current from 0-5V, you should be ok while the pin is active(i.e. the device is ON). You may want a pulldown resistor to just keep the gate low(off) if the pin becomes a high impedence, such as when the device is off or something and you want to make sure the fet is off too. If this is the case, you could use a resistor of 100K or higher. Just don't make it too low, then you'll start having a voltage drop from the 5V pin and you may only get your gate up to 4V or something where the channel isn't fully open.
Tom
You are right about using a series resistor to limit the inrush current, but this is usually for a power fet since they have a fairly large capacitance. A 2N7000 has a typical input capacitance of 60pF, while a power mosfet may have something on the order of 5000pF. A big difference.
As for the resistor, I'm pretty sure he was talking about a pulldown resistor. In that case, 10K is a bare minimum, but the series resistor TomS mentioned is correct.
And Yes I was talking about a Pulldown on the gate. I will try a 10k and see how it reacts ...
Thank You for your advise,
JMLStamp2p
You can try a 10K resistor, but remember, this is only there to keep the gate low. Device driving the pin is on, the pulldown resistor will serve no purpose, and will infact, increase power consumption when the pin is high. At 5V with the pin high, the pulldown will be drawing 2.5mW just sitting their. a 100K will pull 1/10th of that. If power isn't an issue in your design, a 10K will be fine, but again, it is ONLY to ensure the gate stays low while the device is off.
Paul Baker
