BB_FullDuplexSerial
What function does the·random seed·play in the repeat loops?· The original version of FDS doesn't use them and seems to work fine.· For example:
It also seems I've found a bug.· Shouldn't the fixed mask in the tx method also vary depending on the size of the buffer?· Mike's code is:
I'm specifically referring to the $F in the repeat loop.
Tom
repeat while (rxbyte := rxcheck) < 0
?long[noparse][[/noparse]def#randomSeed]
PUB tx(txbyte)
'' Send byte (may wait for room in buffer)
repeat until (tx_tail <> (tx_head + 1) & $F)
tx_buffer[noparse][[/noparse]tx_head] := txbyte
tx_head := (tx_head + 1) & def#txPtrMask
if rxtx_mode & %1000
rx
Tom
You can leave out the random seed. FemtoBasic has a random function. Both FDS and the keyboard input routines "stir" the seed when waiting to add some randomness to the value.
Thanks for the bug find. I had found and fixed it in my working copies, but I haven't updated the Object Exchange version since February. I'll do it this weekend.
I found what I would call a limitation rather than another bug. The rx buffer size is limited to 32 bytes or smaller (rxBufSize = 1 << 5).· It seems to affect the tx portion of the code.· I haven't attempted to find the problem as I'm not sure it's worth the trouble.· I just thought I'd let you know.· You might want to put a comment in the code.
Tom
What are the symptoms? I'm not aware of a problem with the rx buffer size. It should work for any buffer size up to 256 bytes.
Post Edited (Mike Green) : 4/25/2008 4:03:34 PM GMT
The transmitted stream gets out of order. It looks like the end is transmitted before the beginning.· Actually it looks like the buffer isn't being flushed.
Tom
Post Edited (TomS) : 4/25/2008 4:06:40 PM GMT
This is an error in the FullDuplexSerial driver in general. In the transmit assembly code, there's a comparison between tx_head and tx_tail, but the code is actually comparing tx_head and rx_tail. It's strange why this hasn't shown up earlier. I'll fix it in my versions and change my code to support arbitrary sized buffers as well and post the fixes to my versions tonight or tomorrow. You might try fixing it yourself and see if it works better for you.
Maybe I'm the only one pushing it. I really don't need a large rx buffer but thought I would "kick the tires" so to speak. As in any software project its difficult to test for all possibilties. I'll look for your fixes this weekend.
Tom
add t1,#4 'get buffer_ptr rdlong rxbuff,t1 mov txbuff,rxbuff 'offset to rx buffer add txbuff,rxPtrWrap add txbuff,#1Is this calculating the address of the tx buffer based on the start and length of the rx buffer?
