Anyone Try Sparkfun's 3.5 TFT LCD ? — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2008-04-24 12:59 in Propeller 1
Thinking about trying this one. Anyone have experience with it?
http://www.sparkfun.com/commerce/product_info.php?products_id=8490
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
  • RaymanRayman Posts: 15,390
    edited 2008-04-23 16:35
    I thought about that one but then decided it would be cheaper and easier to just use a NTSC LCD...
  • jazzedjazzed Posts: 11,803
    edited 2008-04-23 16:52
    Got a pointer to an NTSC LCD source?
    (Still looking for feedback on original question.)
  • WinWin Posts: 21
    edited 2008-04-23 23:54
    I haven't tried the Sparfun LCD, but Parallax sells a nice compact composite LCD for
    about $80 or $90. Or you can try rolling your own for about $25. This was in an earlier
    thread, but see this link for what I did. There's a link there to the instructions too.
    http://wsh.homeunix.org:8080/~izzy/Site/Blog/Entries/2008/4/6_CyberHome_mini_DVD_Monitor_Hack.html
    Works well.
    Win
    edited 2008-04-24 00:20
    The link to that homebrew monitor is:
    www.orrtech.net/propeller/cyberhomedvdplayer.html
    But you will have to buy them from Ebay, as I don't think geeks has them anymore.
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Got an SD card? - PropDOS
    A Living Propeller FAQ - The Propeller Wiki
    (Got the Knowledge? Got a Moment? Add something today!)
    edited 2008-04-24 04:59
    COnnecting a Propeller to a TFT display, like the one linked to at SparkFun, isn't a good idea for the Propeller. One of the main reasons is the memory. If you are wanting to do a graphics driver or something similar, the memory gets to be the big problem. The Propeller has only so much ram to work with. The TV or VGA drivers work well, but also do some tricks to try and minimize memory. I suppose those same tricks could be used for the TFT as well.
    I have been working with the uOLED and soon another OLED screen. At the moment I don't see speed in writing to the display an issue as much as the video memory in the Propeller.
    Timothy D. Swieter
    www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
    www.tdswieter.com
    One little spark of imagination is all it takes for an idea to explode
  • Ken PetersonKen Peterson Posts: 806
    I think it's possible to drive a parallel RGB display with a modified VGA driver. The overall timing is similar, but you would need to produce a dot clock signal (by using PLL mode 2 or 3 instead of 1) and perhaps change some of the other signals. You will only get two bits per color, however, with one cog. ·If that's all you need then it's theoretically doable. If you need more color depth you can use more cogs but you will quickly run out of memory for the screen buffering (see Timothy's commments).· In order to drive 8 bits RGB with 2 bits from the Propeller, connect MSB to bits 7,5,3 & 1 and LSB to bits 6,4,2 & 0 in order to gain maximum color range on the display.
    This is something I have considered trying, but I have not yet had the time to do it.· Also, some LCDs need to have constantly alternating voltages on the drive signals. I'm not sure I understand how this is supposed to be done. This one may not need that.
    Post Edited (Ken Peterson) : 4/24/2008 1:05:17 PM GMT
