Serial problems (solved)
computer guy
I have a "matchport b/g" connected to a propeller and they will not communicate.
The propeller is running FullDuplexSerial and I have tried all of the modes (0-3) and it is set for 9600 baud.
The "matchport b/g" is configured for the following.
RS232
8 bits
1 stop bit
no flow control
9600 baud
Using my Parallax USB Oscilloscope I have determined that they are going from (logic level) high to low fine. (3.3v to 1.7v aprox)
I can get both devices to talk to the PC via a prop plug but not to each other.
Does anyone know what might cause this?
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Building Blocks To The Propeller Chip
Post Edited (computer guy) : 4/23/2008 3:20:59 AM GMT
RS232
8 bits
1 stop bit
no flow control
9600 baud
Thank you
Logic low should be lower than 1.7V.· That may be a sign that you have things reversed.
Serial Interfaces
The MatchPort b/g serial interface is 3.3V logic level and typically connected to a
Universal Asynchronous Receiver/Transmitter (UART). For connection to an external
device, the demo board has RS-232/422/485 transceivers. CON1 and CON2 support
RS-232/485. Connect to a PC using a null-modem serial cable with 9-pin connectors
(F/F).
The table below lists the RS-232 signals and corresponding pins on the MatchPort
b/g. All signals are level-shifted by the RS-232 transceivers
Table 3-1. RS-232 Signals
MatchPort b/g
PIN FUNCTION
DB9
Pin #
UART x Conx
http://www.lantronix.com/pdf/MatchPort_IG.pdf
TXDx (Data Out) 3
RXDx (Data In) 2
CTSx (HW Flow Control Input) 8
RTSx (HW Flow Control Output) 7
DCDx (Modem Control Input) 1
DTRx (Modem Control Output) 4
Aka: CosmicBob
I have the following connections.
Matchport **** PropPlug
TX
> RX
RX <
TX
GND <
> GND
OR
Prop **** PropPlug
TX(P26) ----> RX
RX(P27) <---- TX
GND <
> GND
OR
Matchport **** Prop
TX
> RX(P27)
RX <
TX(P26)
GND <
> GND
*Doesn't work
*Works
Thank you
Post Edited (computer guy) : 4/23/2008 2:28:20 AM GMT
I wound the window down and up a few times and now it works.
Jesse
W5JCD
Assuming you are asking if I am using braypp terminal.
I use Putty or Hyper Terminal for serial coms.
Post Edited (computer guy) : 4/23/2008 5:38:06 AM GMT
