servo Questions
I have a costume that uses 6 servos.. 2 from fma, and 4 from hitec.
my question is this. the manual for the USB servo controller shows a 7.2volt rc battery pack, can the servos stand 7.2volts.. I thought 6volt was the max for them
2 of the servos are hitec digital ones.. do they have a lower max voltage?
thanks [noparse]:)[/noparse]
or change it to 7.2 volt rechargeable. (I got some nice nicads from radio shack, they had the vex powerpack on clearance for $6, normal price 50$, comes with 1 7.2volt, 1 9.6 volt and a dual quick charger, (2 hour), so I bought the 2 they had on the shelf.
Given that you have real D cells, I'd stick with the 6V pack (with 5 cells: 5 x 1.2V = 6V).
so a smaller 7.2volt 2000mah pack is fine.. cause I can't wear the costume for more than a hour or 2 anyway. (45lbs or so..·never weighed it.)
I can't wait for the usb servo controller to arrive.
