Keyboard USB vs. PS/2, GPS
Hi All,
I am a newcomer to this world. I bought my first Parallax product a couple of weeks ago, the Propeller Proto Board, together with the GPS receiver and a LCD Display. So far, I have been studying a lot of manuals and existing objects to start the learning process.
I have also done some labs, and to my surprise they have all worked fine! My very old soldering skills, used when I was a teenager, have been reactivated... It's like learning how to ride a bicycle, once learned never forgotten!
My plan is to build a fairly advanced GPS navigator. The maths is completed [noparse][[/noparse]and tested!], like calculating: Great Circle Course, Rumb Line Course, Distance on the Great Circle and Rumb Line, Cross Track Distance, Along Track Distance, Position at Intersection.
I am currently trying to figure out how to connect a keyboard to the board. How to connect a PS/2 based keyboard looks, as far as I understand, quite straightforward. However, the the heavy duty, water resistant I want, connects via USB.
Now, my question...
Can the USB keyboard be as easy connected as the PS/2 one?
Have a feeling the answer is no...
Looking forward to some good advice.
P.S.
My name is G
Now, my question...
P.S.
My name is G
If you can find something which can host a USB keyboard and will interface to a serial, I2C or SPI bus that would do it but the Propeller cannot work as a USB Host.
I have found a little bugger that probably will to the trick at: http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11298/subcatid/0/id/124184
But unfortunately it is currently out of stock at this distributor, hopefully not forever...
Cheers,
G
Check the packaging your keyboard came into to see if any mention of PS/2 is made. I'd hate for you to buy the adapter only to find that your keyboard doesn't support PS/2 signaling (in which case the adapter wouldn't help you to interface your keyboard with the Propeller).
Paul Baker
I was only looking at the wrapping of the device and it said "USB to PS/2 Adaptor", but it does the opposite!
Typically USB keyboards that also support PS/2 signaling ship with the USB to PS/2 adapter
The keyboard is waterproof, flexible and cost $3 (retail in the U.S). So, I suppose that after the VAT that would be $12 in Europe. It sas a USB to PS/2 adapter on a dongle.
MD85618... made in China.
Rich
Would you post a link to that distributor? (Just finished some Aldi's boxed chicken, love that stuff [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Paul Baker
