Date Time and Temp
I have added a DS1620 to my clock project and I am having a problem getting a good tempreature.
I used CNVRT_F a C to F conversion I found on the forum, but I am not sure I am getting a good read from the DS1620. The GET_TEMP subrutine
The clock protion of the program works fine
I have tried to optimize the program as best as I could, It uses a lot of program space.
I attached the program "Clock_12_rev2_tmp.SXB"
It's to big to post.
If anyone could look it over, I could use the help.
I feel I dont give enough information ot I am not to the point
I am trying to do better
my goal was to set the DS1620 to work with a CPU in one shot mode.
Start a tempreature conversion and wait for conversion to complete by monitoring bit 7 of the configuration register.
Then read the tempreature, first 8 bits to degC, the ninth bit into signC, and then gosub to CNVRT_F to convert to Fahrenheit.
here is the subrutine
INT_DS:
DS_Reset = 1 ' select device
SHIFTOUT DS_I_O, DS_Clock, LSBFIRST, WriteConfig '
SHIFTOUT DS_I_O, DS_Clock, LSBFIRST, %00000011 ' (%00000010-CPU, continuious)(%00000011-CPU, one-shot)
DS_Reset = 0 ' deselect device
WAIT_MS 10 ' allow DS1620 EE to write
RETURN
GET_TEMP:
DS_Reset = 1 '
SHIFTOUT DS_I_O, DS_Clock, LSBFIRST, StartConvert ' start conversion
DS_Reset = 0 '
WAIT_MS 10 ' pause before shiftout
DO '
DS_Reset = 1 '
SHIFTOUT DS_I_O, DS_Clock, LSBFIRST, ReadConfig '
SHIFTIN DS_I_O, DS_Clock, LSBPRE, tmpB1 '
DS_Reset = 0 '
LOOP UNTIL tmpB1.7 = 1 ' Wait for conversion to complete
DS_Reset = 1 '
SHIFTOUT DS_I_O, DS_Clock, LSBFIRST, ReadTemp '
SHIFTIN DS_I_O, DS_Clock, LSBPRE, degC ' get temp 8 bits
SHIFTIN DS_I_O, DS_Clock, LSBPRE, signC\1 ' get sign 1 bit
DS_Reset = 0 '
degC = degC + degC.0 ' round up
degC = degC >> 1 ' remove half bit
degC = degC - 3 ' I don't know why it just works better
CNVRT_F degC '
RETURN
My question concerns these lines of code.
these two lines came from the SX THERMOMETER example program in the help file.
I dont totally understand them i just used them as they were
I added this line because my readings were always higher than my reference by 8 to 10 degeers
between the range of 70 - 80 degrees F this works (displays the correct temp in that range) but I am not sure if it is a fix, or just a trick.
is there an error or something wrong with my code or could it be a inaccurate chip
attached is the full program "Clock_12_time_date_temp.SXB"
mike
The LSB represents only 0.5 degrees C.
The degC.0 is rounding the reading DOWN to an integer C amount and then the >> 1 shifts the reading so that you have a nice integer that you can display. If you didn't do that your reading would be twice what it should be. The -3 is the equivalent of subtracting 1.5C from your reading. However, if you do not do the shift then your reading is going to be off.
The MSB (the 9th bit) is actually a sign bit. You could check this bit and if = 1 then the temperature is below freezing.
Because you can read up to 125C these sensors are perfect for atmospheric readings and it would be rare that you get above 50 deg C (122 deg F).
Remember that when reading wind temperature, the temperature can vary by a couple of degrees several times a minute. Thus, sacrificing the half of a degree is generally not a problem.
Edited:
Oops, forgot to post datasheet·reference
http://pdfserv.maxim-ic.com/en/ds/DS1620.pdf
John J. Couture
San Diego Miramar College
Post Edited (John Couture) : 4/27/2008 9:36:21 PM GMT
the resolution I am getting reading the DS1620 is 1.8 ºF instead of .9ºF as the data sheet says.
I have tried one shot and continuious mode I even tried another new chip same thing.
I tried·getting the tempreature once a minute,·twice a minute and continuious readings always
the same 1.8 ºF·instead if .9ºF.
How can I change/fix this this.
mike
The Digital Thermostat code for the BS2 at the following link offers 1 degree of resolution. I was having the same problem and it was due to the math being done on the BASIC Stamp. Tracy Allen showed me a way to convert to Kelvin First to save some loss. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=519605
I am still using the CNVRT_F subroutine from the C_to_F__V3 mike-cook posted.
I changed the first few lines that got rid of the fractional part.
After converting to Fahrenheit, degrees F advances 1 degree every .5 degrees C.
from the thermometers I have to check it by it seems to work ok.
I have a question about these lines of code.
They advance the clock registers to set the clock when a button is pushed.
Is there any way to optimize this routine to save program memory and achieve the same result.
SET_CLOCK:
·DO·················································································· '
·· IF BtnMins = 0 THEN······················································ ' minutes
· INC Mins········································································· '
··· Mins = Mins // 60····························································' minutes = 0 to 59
· LCD_OUT LcdLine0_11····· ······················· ··········· ··········· '
· GET_DEC Mins································································
··· WAIT_MS 250·································································
·LOOP UNTIL BtnMins = 1···················································
·· ENDIF············································································
·DEC2BCD Mins································································
·Mins = tmpB2··········································································
·DO··················································································· '
··· IF BtnHrs = 0 THEN························································ ' hours
· INC Hrs············································································ '
·· Hrs = Hrs / 13································································· ' hours 1 to 12
·· Hrs = __REMAINDER | Hrs·············································· '
···· IF Hrs = 12 THEN························································· '
···· tmp1 = ~tmp1·············· ······················· ··········· ··········· ' change AM PM
···· ENDIF·················································································
· LCD_OUT LcdLine0_8···································································
· GET_DEC Hrs········································································
··· WAIT_MS 250··································································
·LOOP UNTIL BtnHrs = 1·······················································
·· ENDIF···················································································
·DEC2BCD Hrs·········································································
·Hrs = tmpB2············································································
· Hrs_Bit_5 = tmp1················ ······················· ··········· ··········· ' change am pm bit
· Hrs_Bit_7 = 1· ······················· ······················· ··········· ··········· ' has to stay 1·· for 12 hr···········
