39 kHz IR Beacons for Robot Detection & Navigation
I wanted to share my recent findings on creating simple, cheap·IR beacons that our Scribbler & BoeBots can detect. There have been numerous posts about IR signals, and·especially good info on sending data back & forth between two Stamps. My interests have to do with robot navigation, and sending out a detectable IR signal from one or more stationary beacons. A number of posts, and at least one ROBOT magazine featured Propeller-powered project, suggest using Roomba virtual walls or microprocessor-controlled beacons. These options get expensive when more than one beacon is desired. I wanted a cheaper·circuit·using·readily available·parts.
BTW, there is lots of info out there, and plenty of great Parallax downloads. I read through most of that to reach a solution.
IR control signals are essentially·Morse Code-like·pulses on a carrier frequency of 38-40 kHz. I·favor 39 kHz for wide compatability.·You can build a very simple circuit to generate an unmodulated 39 kHz·IR signal using a 555 timer. While easy to understand and construct, this will not yield a usable signal.
Most IR receiver modules (including the one built into the Scribbler robot, and probably in the Boe-Bot kit) won't give a continuous low output signal when receiving a continuous 39 kHz carrier. They'll drop low for less than a second, then go high until the beam is interrupted once again. They are optimized for receiving a modulated signal, not detecting a steady one. Waitrony DOES make a special IR receiver module (identical packaging, just a different model number) that can detect an unmodulated signal. I don't have the·model number handy, but I'll get it and post it ASAP.
After some legwork, I DID make an IR beacon from a 556 timer that a standard IR receiver module (such as found in the Scribbler/BoeBot) can detect. The 556 is a dual 555 timer, and·my circuit·uses one timer to generate the 39 kHz carrier and modulates it with the other timer. Additionally, I can make multiple beacons modulated at slightly different frequencies, and the Stamp/Robot can·distinguish between beacons·using the COUNT command to count received pulses in a given interval.
A standard 556 tone burst circuit won't work, because it outputs a 50% duty cycle and most IR receiver modules just don't like that; they respond intermittently, just·like a·simple 555 oscillator. I found a great website with 555/556 info at http://www.kpsec.freeuk.com/555timer.htm·and they showed how adding one simple diode can drop the duty cycle below 50%. The IR receiver LOVES that. I'm attaching my beacon circuit here for interested parties. The modulation frequency is ~1.35 kHz with the values shown. Tweak the RC values on the LEFT side of the schematic to vary the modulation frequency if you want several distinctly different beacons for whole-house navigation. The right-side components generate the 39 kHz signal. You can adjust that to 38 or 40 kHz with the 10K pot based on your particular receiver module.
I used two Radio Shack IR LEDs aimed ~30 degrees apart to send a wider beam. Using the series 82-ohm resistors shown, my Scribbler can detect and track this·signal reliably from 20+ feet away. Hope this info helps anyone going down this road.
bmp
674K
beacons and if so, when does the infrared from one transmitter
interfere with another?
humanoido
Post Edited (erco) : 4/21/2008 2:09:24 AM GMT
Replacing the similar-type unit found in Scribbler and BoeBot applications would make receiving certain non-standard signals possible, including a continuous signal from an ultra-simple 555 timer beacon.
Having said that, they·appear difficult to locate. I work in a lab with several samples of each type receiver, but a quick Google and·Digikey search didn't reveal any online sources. Will advise if I learn differently.
humanoido
If anyone is interested, send me a private email.
