I'm confused about the volume of SRAM — Parallax Forums
John KauffmanJohn Kauffman Posts: 653
edited 2008-04-21 14:34 in General Discussion
I'm confused about the amount of SRAM on the SX28.
The SX28 datasheet specs the chip with " 136x8 bits SRAM " (page 3).
Out of curiosity I started adding variables to an empty program & assembling.
DEVICE· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··· 4_000_000
Variables
var00·var·byte
var01·var·byte
var02·var·byte
var03·var·byte
PROGRAM Start
Start:
Main:
GOTO Main
Up to var18 there is no assembly problem.
When I add var19 I get an assembly error that "variable exceeded available RAM."
From the datasheet I predicted that I could declare 136 byte-size variables.
Can someone explain this? Thanks.
  • BeanBean Posts: 8,129
    edited 2008-04-19 12:52
    John,
    The rest of the RAM is used for Arrays.
    Bean.
    Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
    www.iElectronicDesigns.com
  • John KauffmanJohn Kauffman Posts: 653
    edited 2008-04-19 13:15
    I used arrays in the past to make looping through values easier. Now I see that putting values in arrays also makes available an additional 108 bytes. This is great news, I had been fighting to squeeze my projects into only 19 variables.
    I add to my program 12 arrays of 9 bytes each with no assembly problem.
    varArr01 var byte(8)
    varArr02 var byte(8)
    varArr03 var byte(8)
    varArr12 var byte(8)
    But VarArr13 causes the VARIBAL EXCEEDED RAM error.
    So I have:
    19 single bytes = 19 bytes
    12 arrays of 9 bytes each = 108 bytes
    Total = 127 bytes
    Datasheet says 136
    Missing = 9 bytes
    Not to be a stickler, but I'll learn something more about SX if I can figure out where the other 9 bytes are located. Is it conincedence that the 9 missing bytes would be one more array scoped to (8)? Am I counting my arrays wrong?
    Code below.
    Variables
    var01 var byte
    var02 var byte
    var03 var byte
    var04 var byte
    var05 var byte
    var06 var byte
    var07 var byte
    var08 var byte
    var09 var byte
    var10 var byte
    var11 var byte
    var12 var byte
    var13 var byte
    var14 var byte
    var15 var byte
    var16 var byte
    var17 var byte
    var18 var byte
    var19 var byte
    ' var19 var byte ' #19 exceeds ram
    varArr01 var byte(8) ' (8) = 9 bytes each
    varArr04 var byte(8)
    varArr05 var byte(8)
    varArr06 var byte(8)
    varArr07 var byte(8)
    varArr08 var byte(8)
    varArr09 var byte(8)
    varArr10 var byte(8)
    varArr11 var byte(8)
    'varArr13 var byte(8) ' #13 exceeds ram
  • ZootZoot Posts: 2,227
    edited 2008-04-19 16:17
    There are a number of quasi-hidden registers in use if you are using SX/B -- the __PARAM vars all take up space, the __REMAINDER var, the "shadow" registers for pin directions and states, etc. The only way to free up the bit of extra ram is to program wholly in assembly.
    In a technical sense, when you declare individual VARS, these go into the BANK 0 registers (some of which are already in use by the requirements of the chip and/or SX/B). When you declare "arrays" those go into BANK 1 ... BANK N where N is dependent on the chip (SX28 or SX48). You CAN set up individual vars in the "arrays" though, if you want, like this:
    someArr VAR Byte(8)
    someVar VAR someArr(0) ' alias to first element of someArr
    So you can now use someVar like any other variable, although accessing may take up more code space (in assembly; you won't see it in SX/B) because of the way the FSR is used to access the higher banks of ram.
  • John BondJohn Bond Posts: 369
    edited 2008-04-21 14:25
    When are you allowed to use array variables as veriables and when can you not use them. I discovered last night that For...Next doesn't like array variables.
    John Bond
    John,
    You cannot use them as FOR...NEXT control variables. And you cannot use them as the index of another array.
    Other than that, you should be able to use them anywhere else.
    Bean.
