Can I use this crystal with the Propeller
I have a difficult time understanding some of the requirements of a crystal to be hooked up to the propeller.· I don't get series-mode, parallel-mode, HC/US-29 or whatever.· I usually use oscillators, but I thought I would give crystals a try since they use less power, according to my current understanding.
So, can I use the 12.5 MHz crystal linked-to·below with the Propeller and PLL8x?· (Yes, I want to overclock to 100MHz).
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=300-8432-ND
Thanks!
Thanks!
1) The PLL is supposed to work with fundamental crystals from 4 to 8MHz. The Propeller has been used with 10MHz crystals as with the Hydra and the Spin Stamp, but that's considered to be "pushing it". Even though the PLL tap is at 8x, the PLL is still trying to run at 200MHz which is well beyond its range.
2) The crystal load capacitance is specified as 18pF. You would need to use the XTAL3 setting to get something close to that. The other settings are higher and will shift the crystal frequency from its specified frequency.
Does there exist a 6.25 MHz crystal that will work with the Propeller and is available for purchase in the US?
This SX program was used to run my Propeller at 100 MHz by hooking RA.0 to the XI pin of the Propeller:
Doug
