RF Transmitter and Receiver
I am using the Parallax RF 433 MHz RF modulues on a project and I am experiencing some difficulity with the serial communication.··The SX is runnung at 4 MHZ (external) and·the baude rate is "N9600".··Some communication does occur but the data is garbage.· I am trying to send a byte every·2 seconds.··I have looked at the Basic Stamp·example code for this and it seems simple, but I must be missing something when I apply this to the SX.
Post the code you are using.
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
if we only would know if you are programming the SX in Assembly or SX/B ... plus a copy of your program code would tremendously increase the ability (and motivation) of other forum members to give you the right directions.
Greetings from Germany,
G
