Servo Arm Controls
Here's a tough problem I can't get around.· My program below runs my servo motors through a demo routine of movement.· It works, but only as long as the debug statement is in the code and as long as I leave the debug window oen.· If I remove the debug statement the servos twitch, then do nothing.· If I close the debug window after it opens the program stops and the servos go dead (the arms drop).
I'd like it to run in a loop with out the debug statement effecting the program one way or another.· Any suggestions on how to do that?
Thanks for reading.·
-Justin·· Weyoun7@aol.com
Here is my code:
'Generic values
i· VAR· Byte····· 'loop counter, whatever
'These are for the servo routines
LEFT_HAND··· CON·· 3····· 'left wheel port
LEFT_ELBOW·· CON·· 1····· 'right wheel port
NECK········ CON·· 10····· 'neck servo
RIGHT_HAND·· CON·· 4
RIGHT_ELBOW· CON·· 7
'troubleshooting routines
DEBUG "Yul Demo is Online!",CR
Main:
FOR i = 1 TO 100
·· PULSOUT LEFT_ELBOW,879
·· PULSOUT LEFT_HAND,769
·· PULSOUT RIGHT_ELBOW,769
·· PULSOUT RIGHT_HAND,769
·· PULSOUT NECK, 765
·· PAUSE 20
·· NEXT
GOTO RArm
RArm:
FOR i = 1 TO 100
···· PULSOUT RIGHT_ELBOW, 769
···· PULSOUT RIGHT_HAND, 969
···· PULSOUT NECK, 665
···· PAUSE 20
···· NEXT
···· GOTO RArm2
RArm2:
FOR i = 1 TO 100
···· PULSOUT RIGHT_ELBOW, 569
···· PULSOUT RIGHT_HAND, 769
···· PAUSE 20
···· NEXT
···· GOTO RArm3
RArm3:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO RArm4
RArm4:
FOR i = 1 TO 100
···· PULSOUT RIGHT_HAND, 469
···· PULSOUT NECK, 965
···· PAUSE 20
···· NEXT
···· GOTO LArm
LArm:
FOR i = 1 TO 100
···· PULSOUT LEFT_ELBOW, 769
···· PULSOUT LEFT_HAND, 900
···· PULSOUT NECK, 765
···· PAUSE 20
···· NEXT
···· GOTO LArm2
LArm2
FOR i = 1 TO 100
···· PULSOUT LEFT_HAND, 469
···· PULSOUT NECK, 565
···· PAUSE 20
···· NEXT
···· GOTO Main
END
Here is my code:
'Generic values
Main:
FOR i = 1 TO 100
·· PAUSE 20
·· NEXT
GOTO RArm
RArm:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO RArm2
RArm2:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO RArm3
RArm3:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO RArm4
RArm4:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO LArm
LArm:
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO LArm2
LArm2
FOR i = 1 TO 100
···· PAUSE 20
···· NEXT
···· GOTO Main
END
can always give it a try).
Try various ranges of 20 to 500 for the pause.
Also, good programming style is to use PIN instead of CON when defining names for pins.
Disclaimer: I'm a newbie, take my advice at your own risk.
This is plain a Basic Stamp II, I have not used PIN before like that, but I gave it shot, a run time error "Expected ':' or end-of-line" popped up when I replaced CON with PIN.
It's weird, because when a dugbug statement is ran and as long as the debug window is open, the servos move and stay in their correct position until the code directs them to move again.
If the debug statement is removed or the debug window is closed, the first servo will move to it's position and then instantly disengage and the robot goes limps and stops moving. But put the debug statement in and leave the debug window open and bingo-bango everything works right. Except I want to work without a debug window.
Are the servos powered from the same source as the Stamp?
I've also tried different servos and I get the same results.
To test the idea of it being power I removed all the pulsout line except for the NECK and to that port I connected a single servo with nothing connected to it (no load). I ran the program with the debug line and it work. I removed the debug line and I got the same resoults as before, the servo moves to it's first position then it stops moving.
I thought it was a power issue at first also, but from those resoluts do you think it may still be a power issue?
Thank you guys for your help and suggestions!
-Justin R.
By the way, Servo's are designed for 5 volt to 6 volt to MAYBE 7.5 volt use. Any voltage above that will reduce servo life. If you care about that.
The solution is to get a 6 volt 5 amp power supply and try that.
This could ALSO be a "grounding" problem.· The BS2 supply ground wire and the 9-volt supply ground wire ARE tied together, right?· It's possible the PC cable is providing a "common ground" for both, when this is removed the the servo's don't properly recieve the BS2 signal.
I don't want to argue about the voltage requirements, but I do not believe my standard servos need 5 amps when the BoeBot and Toddler run regularly off of AA battery packs and from any specs I have seen on a AA battery they typically can't sustain even 1amp.
My regulators are not overheating. I used the above code with all servo lines removed except for the neck servo and ran it under no load and powered it via 4 AA's at 6 volts and 6 AA's at 9 volts, any power combination I try I get the same results.
You are right, 9 volts is above the specs for most servos. I like to run my servos closer to 9 volts, I have not killed a servo yet from that.
The key problem for me with this code and Basic Stamp is when a Debug statement is in the code and the Debug window is left open the servos move as they should. Remove the Debug line or close the debug window and it's like the code jumps to the end statement. It's really weird to see. This should be a simple function.
Here is my new test program for the neck servo:
i VAR Byte 'loop counter, whatever
NECK CON 10 'neck servo
console CON 16 'Serial I/O to PC
cmdchar VAR Byte 'Charactor from command stream
cmdbaud CON 3313 '300 baud
Main:
SERIN console, cmbaud, [noparse][[/noparse]cmdchar] 'Get the command key
IF cmdchar = "x" THEN Serv1
IF cmdchar = "u" THEN Serv2
GOTO Main:
Serv1:
FOR i = 1 TO 100
PULSOUT NECK, 765
PAUSE 20
NEXT
GOTO Main
Serv2:
Pulsout NECK, 1265
pause 100
GOTO Main
Ok, no debug line in this at all. But, this program lets you use a debug window or other serial terminal link to send keyboard X and U commands to the Basic Stamp to control a servo. From the windows stamp editor you can click on RUN, select DEBUG, NEW then select your COM port and set the Baud to 300. From there you can enter in an X from the keyboard and as long as the Debug window or some other terminal window is open and keeps an open connection the servo will stay at position 765 for a count of 100 even under load or if you try to manually move the servo horn it will push back and keep position 765. After it completes it's 100 count the servo goes limp and can be freely moved.
What I now think the problem is with a debug window the Stamp is forced to enforce the position of that servo for the 100 count so it forces the PULSOUT to keep the servo at position 765 until it reached 100 in the FOR NEXT loop.
Where as if a terminal link was not made with the Basic Stamp then in the very same FOR NEXT loop it'll move the servo to position 765 and then it think it's job is done does not follow through with the PULSOUT command for the count of 100 in the FOR NEXT loop.
What else is interesting is if were to run the same FOR NEXT loop with a servo modified for continuous rotation, it happens to run at whatever number I give it for the duration of the FOR NEXT loop weather a debug window is open or not because a modified servo does not have the internal position feedback.
So, what I would need is a way to program the Stamp to enforce the PULSOUT for the duration of the FOR NEXT loop on it's own without a debug window. Perhaps this why most robot arms projects use an external servo control board?
Post Edited (Justin Ratliff) : 4/19/2008 7:23:31 AM GMT
Just as an aside, you may like to know about another command to read data into a program. Take a look at the PBASIC Reference Manual, or the Editor Help File, and look at the DEBUGIN command.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
