UDN2981 Specs — Parallax Forums
UDN2981 Specs
DigitalDjDigitalDj Posts: 207
edited 2008-04-22 12:34 in General Discussion
Hello,
Can someone tell me what the maximum overall current of the UDN2981? I need to draw 325ma at 50% pwm duty cycle per output and want to make sure it will handle that.
Kevin
    edited 2008-04-17 03:13
    There is a graph on pg 6 of 8, "Allowable peak collector current as a function of duty cycle", and according to it, with VS = 15V and·50% DU, you can draw 225mA from 8 gates or 325mA from 6.
    http://www.allegromicro.com/en/Products/Part_Numbers/2981/2981.pdf
  • DigitalDjDigitalDj Posts: 207
    edited 2008-04-22 01:41
    Thanks PJ seen that but wanted to make sure I was looking at it correctly.
    Kevin
    This·IC is touted as a pancea, because it's easier to "understand" than its cousin the ULN2803.· The Vsat spec is ignored.· 2V across a transistor, with 300mA going through it is 0.6W, and x8 is almost 5W.· It's just a DIP-IC, it has no heatsink.
