Another 3.3V I2C to 5V I2C Topic
HI,
I have made ( and I am using ) the following circuit and I am using this with the PROP and a 5V I2C LCD ( the MODTRONICS 2X16 LCD one I have mentioned in a previous post)
It seams to work but I would like an expert opinion on it as I have seen other solution involving level shifter IC's and mosfets.
But note, I did not have any 9K resistors so I am using 10K instead.
Dave M
Dave M
J
Its probably a good idea to keep the pullups connected to the 5V as this will help ensure that the voltage is greater than whats required for a level 1. See this thread http://forums.parallax.com/showthread.php?p=721553 for some calcs on what voltages you will get. The spec sheet for you device should have the levels you need if you are worried about it.
I built a small vero-board adaptor with this circuit to test and it seems to work,
But my LCD which is 5V also seems to work running the I2C buss at 3.3v ? go figure?
Regards
Dave M
So in the case of a 5v - (5v/2=2.5v) a 3.3v level will read as a "1" and obviously the 0v will read as "0".
James
..... i.e 1v for the Propeller, so below is ....
J
