Parallax Robots Modified ''Penguin with Wings''
Added wings to Penguin, and polished all Aluminum! None or my mods require any modification to the robots at all they simply bolt on to the Bots.
Simply trace the wings from the Penguin body, and add a small extension to them from the top, to connect them to the screws that hold the board on the top of the shoulders. (Also if using Aluminum!
''Be very sure and use 2 rubber spacers to prevent shorts! The rubber servo mounts cut in half work fine!'')
Post Edited (Zax) : 4/16/2008 7:18:49 AM GMT
AND great job, as no Penguins were harmed in the process!
humanoido
