SX-KEY Diagnostic — Parallax Forums
SX-KEY Diagnostic
mojorizingmojorizing Posts: 249
edited 2008-04-16 23:10 in General Discussion
I've been searching for the post/procedure by Guenther that explains how to connect to the Sx-Key w/ Hyperterminal, send the Key a few ascii letters, and it returns with an acknowledgment. This tests the serial connection to the key. I can't find the post or remember the exact wording of the command. Anyone recall this?
Bad spellers of the world untie!
  • VelocitVelocit Posts: 119
    edited 2008-04-16 06:17
    Here it is... it's a good reference thread:
    http://forums.parallax.com/showthread.php?p=619755
    -Paul
  • steve_bsteve_b Posts: 1,563
    edited 2008-04-16 10:40
    Thanks for posting that troubleshooting/debugging thread!
    I still haven't been able to get my SX-key to work....with similar problems (not found...or sometimes seems to work, then comes up not found).
    Would like to get this one repaired, if it needs it, as I really don't want to mess with a USB key (prefer the rs232/serial one).
    Cheers
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
  • mojorizingmojorizing Posts: 249
    edited 2008-04-16 15:19
    That's the post, thanks!
  • Guenther DaubachGuenther Daubach Posts: 1,321
    Steve,
    when your SX-Key seems to work from time to time, but is not found otherwise, it is most likely that it is not defective. Very often, a weak power supply is the reason for problems like this. The SX-Key (serial version) is powered from the target system via the Vdd and Vss header pins, and "solid", stable 5 Volts are expected here. Often, a 10µF tantalum cap attached across the Vdd/Vss pins of the target system's SX-Key 4-pin header helps a lot.
    BTW: I'm untied smile.gif
    Greetings from Germany,
    Günther
