Question on converting passing LONG pointer arrays, then copying to BYTE arrays
Is the gotcha comment below correct, given that packetArg and packetBuf are defined elsewhere (in another object) as
and are called like:
I am away from my propeller right now, but I think that this is what has been causing
my problem with the dest field being set to $00 instead of the passed value of $01.
I was using byte instead of long in the pfSource and PFDest header bytes.
Is this correct or am I missing something basic?
The Enumerations defined in my global object are:
Post Edited (Chuck Rice) : 4/16/2008 3:40:28 AM GMT
long packetArg[noparse][[/noparse]g#maxPacketArgs] byte packetBuf[noparse][[/noparse]g#maxData]
longfill(@packetArg,0,g#maxPacketArgs) packetArg[noparse][[/noparse]g#pSource]:= cMyAddress packetArg[noparse][[/noparse]g#pDest] := dest rs[noparse][[/noparse]dest].sendPacket(command,g#query,@packetArg)
[b]pub[/b] sendPacket(packetFunc,packetType,packetArgPtr) | pBufPtr,pDataPtr,argPtr,n
' Build Packet Header
' gotcha here. The destination is a byte, but the
' argument is passed in a long array. So the index
' into the passed argument array must be long bassed,
' or multiplied by 4 to be byte based.
[b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]g#pfStart ] := g#stx 'Set Start-Of-Transmission
[b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]g#pfSource] := [b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]g#pSource]
[b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]g#pfDest ] := [b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]g#pDest]
[b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]g#pfFunc ] := packetFunc
[b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]g#pfType ] := packetType
' Build Packet Data Section
argPtr := g#pArg1 'Set to first argument
pBufPtr := pBufBase + g#pfData
[b]repeat[/b]
[b]if[/b] [b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]argPtr] <> 0 'Does this arg point to any data?
pDataPtr := [b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]argPtr] 'Get the address of the data to send from the argument
n := [b]strsize[/b]([b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]argPtr]) 'Calc its length
[b]bytemove[/b](pBufPtr , pDataPtr , n) 'move the arg data into the buffer
pBufPtr += n 'add the length of the data to the buffer pointer
[b]while[/b] [b]long[/b][noparse][[/noparse]packetArgPtr][noparse][[/noparse]++argPtr] <> 0
' Build Packet Trailer
[b]byte[/b][noparse][[/noparse]pBufPtr] := g#ETX 'Add End-Of-Transmission byte
' Send the Packet
pBufPtr := pBufBase
[b]repeat[/b]
tx([b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]pBufPtr++])
[b]while[/b] [b]byte[/b][noparse][[/noparse]pBufBase][noparse][[/noparse]pBufPtr] <> g#ETX
#1 'Packet Function Enumeration
GetGPSinfo
GetGPSinfo2
stopMotors
GetCogs
sendPosition
getScanMap
setTargetLatLon
getDistanceAndBearing
doTest
steer
identify
#1 ' Source and Destination Enumerations
NavBoard
MotBoard
ComBoard
xxxBoard
#$F0 ' Enumeration
STX
ETX
#0 ' Packet Field Enumeration
pfStart ' Packet Start
pfSource ' Packet Source Address
pfDest ' Packet Destination Address
pfFunc ' Packet Function
pfType ' Packet Type
pfData ' Packet Payload
pfEOT ' Packet End of Transmission
#0
pSource 'Packet Argument Enumeration
pDest
pArg1
pArg2
pArg3
pArg4
pArg5
Thanks. I will sleep better tonight! [noparse]:)[/noparse]
