Velocity sensor
I need to interface a Ramsey Electronics SG7 radar gun kit with a computer serial port. I’m using a Parallax Basic Stamp 2 Homework kit (I also have access to a Board of Education USB Discovery kit) and an elproducts RS232 module. In my set-up I tapped into the 4518 dual BCD decade counter IC chip on the Ramsey readout circuit board and sent the eight outputs to Pins 8 to 15 on the Homework board. I then wrote a program that was meant to take pins 8 to 15 as inputs , then using SEROUT on pin 1 sequentially send the values to the Tx pin on the RS232 module. When I put a laptop computer into terminal mode and tried to collect field data, I didn’t get a readout just a flashing cursor on the laptop.
Since I’m new to microcontrollers and sensors, I’m in need of some guidance here. Apparently it is not as easy as just hooking up a bunch of modules, as I have been lead to believe. Has anyone tried to use a radar gun as a speed (velocity) sensor? Do I need more code to make the BS2 microcontroller talk to the RS232 module and laptop? Could someone point me to resources that I might use to solve the dilemma I’m having?
Thank you,
Student-T
Thank you,
Student-T
- Stephen
I made sure that I can communicate with the laptop using the Homework board. The debug command worked very nicely. I still would like to do the same thing with the BOE but instead of using a USB to serial conversion cable, I would like to go to a MAX232 module.
Also, has anyone used the Ramsey Electronics Personal Radar Gun. I need to know where to pick up the digital signal to send to the laptop.
Dave D.
If you mean the SG7, since it's a Ramsey Kit, is it possible that you could scan the schematic and upload that for everyone to look at?
I'm sorry that I have taken so long to reply to PJ Allen's request for a schematic of the SG-7 circuit from Ramsey Electronics. I thought it was in their pdf file on the radar gun, but I was mistaken. Please see the attachment for a scanned copy.
Dave D.
