Dim Newbie with dumb question
When I open the configurations panel there are no options for the COM port - just a blank space under 'Serial Port'. The device manager shows the SX Key connected to COM4, but there's no way to tell the IDE!
If I try to download anyway, I get a message that the COM port (COM1?) is in use by another application.
Is the serial port built-in to the computer? Or are you using a USB to serial adapter ?
Can you change the port from COM4 to COM1 (assuming there isn't already a COM1) ?
Are you using the latest version of the IDE ?
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
Any suggestions? Do I need to install a driver? I have reinstalled the most current SK software and no luck.
Chuck
The IDE was just downloaded so it should be current. I am using a USB to serial adapter. I used it successfully with the SX earlier on my work computer, but when I tried it there today, I had a similar problem. At work this time, it did at least allow me to see a COM1 radio button, although I didn't have any choice as to whether or not to select it. The previous time at work I was able to select COM4. There are no buttons shown on my home computer.
As to changing the serial adapter COM port, I don't know how to do that.
Jim
Jim If your are using a laptop make sure it is plugged into the wall and not on battery. I had a problem using an SX-Key on battery, plugged into wall no problem.
Bean,
I downloadeda nd installled USB driver, selected COM 5, but still get a "chip failed connection" error message. Any suggestions?
Chuck
Never mind. I replaced chip and programmer is now working.
Thank you,
Chuck
After speaking with Mr. Bock it seems that the SX-Key IDE is not seeing his USB to Serial Adapter COM port, even though it shows up in the Device manager. It worked once before. I do recall seeing a message before that PJMonty was involved in where it wasn’t detecting certain types of USB Adapters depending on how they registered in the system. I’m not sure what the fix was for this. His SX-Key Editor shows no available COM Ports. So for some reason it is not seeing what is there. I have given him some stuff to try, however I would like to see if Peter knows what he might try or some test for detecting the ports.
It is also nice to clean out definitions for ports you've only used once. I had to program some FTDI chips and once my system got up to COM40 or so I thought it would be a good time to clean them out and start fresh. Now I only have the ones on the system that I need.
Robert
Next step is to get hold of another adapter.
I have alerted the author of the IDE to this thread to see if there is anything he can offer or suggest. Take care.
http://www.parallax.com/Default.aspx?tabid=460
Version·3.2.92h BETA·includes code that should fix the problem with the Keystone adapter (if, indeed, it works with the current BASIC Stamp Editor just fine).
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
