BOE problems
I am using a BOE trying·to make a monster with a tongue that goes out, picks up an item and comes back.·I am·using the following coding. The problem is that it goes out just fine. Coming back the servos that are sliding the tongue back start jumping rather than coming back smoothly. Thus the back motion takes a long period of time.
Can anyone look at the coding and tell me if there is a mistake in it?
DFly
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
BACKCOUNTER VAR Byte
TOP CON 650
BOTTOM CON 850
DO
DEBUG ? IN3
IF IN3 = 1 THEN
FOR counter = 1 TO 255
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 15
NEXT
FOR counter = 255 TO 1
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 20
NEXT
FOR counter = 1 TO 112
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 20
NEXT
FOR BACKCOUNTER = 1 TO 255
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· DEBUG ? BACKCOUNTER
· PAUSE 20
NEXT
FOR BACKCOUNTER = 255 TO 1
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
FOR BACKCOUNTER = 1 TO 200
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
END
ELSEIF· IN3 = 0 THEN
· PULSOUT 12,750
· PULSOUT 13,750
· PULSOUT 14,750
· PAUSE 20
ENDIF
LOOP
Post Edited (chsom) : 4/15/2008 2:20:58 AM GMT
DFly
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Byte
TOP CON 650
BOTTOM CON 850
DO
DEBUG ? IN3
IF IN3 = 1 THEN
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 15
NEXT
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 20
NEXT
· PULSOUT 12,850
· PULSOUT 13,650
· PULSOUT 14,725
· DEBUG ? counter
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
· PULSOUT 12,TOP
· PULSOUT 13,BOTTOM
· PULSOUT 14,850
· PAUSE 20
NEXT
END
· PULSOUT 12,750
· PULSOUT 13,750
· PULSOUT 14,750
· PAUSE 20
ENDIF
LOOP
- Stephen
Thanks...
