ASM: heartbeat (blinking led)
Hello,
After programming a heartbeat (just a blinking led) in spin, I tried programming it in ASM.
But it isn't working
Here is my program:
It also contains the working one, in SPIN. (see PUB start)
Any idea how to fix this?
Kind regards,
Robot Freak
Post Edited (Robot Freak) : 4/14/2008 5:57:11 PM GMT
Here is my program:
{{ heartbeat.spin }}
[b]CON[/b]
[b]_clkmode[/b] = [b]xtal[/b]1 + [b]pll[/b]16x
[b]_xinfreq[/b] = 5_000_000
[b]VAR[/b]
[b]LONG[/b] stack[noparse][[/noparse]20]
[b]BYTE[/b] id
[b]PUB[/b] start_asm
id := [b]cognew[/b](@asm_start,0)
[b]PUB[/b] start
id := [b]cognew[/b](beat,@stack)
[b]PUB[/b] stop
[b]if[/b] id == -1
[b]abort[/b]
[b]cogstop[/b](id)
[b]PRI[/b] beat
[b]repeat[/b]
![b]dira[/b][noparse][[/noparse]22]
[b]waitcnt[/b](40_000_000 + [b]cnt[/b])
[b]DAT[/b]
[b]org[/b] 0
asm_start
[b]mov[/b] [b]dira[/b], pin_true 'Set pin 22 output
[b]mov[/b] wait_var, [b]cnt[/b] 'Set variable wait_var to cnt
[b]add[/b] wait_var, delay_var 'Add delay_var to wait_var
:[b]repeat[/b] [b]waitcnt[/b] wait_var, delay_var 'Wait 1/2 sec
[b]mov[/b] [b]outa[/b], pin_false 'Set low
[b]mov[/b] [b]outa[/b], pin_true 'Set high
[b]jmp[/b] :[b]repeat[/b] 'Jump to repeat
pin_true [b]long[/b] $1<<22
pin_false [b]long[/b] $1<<22
delay_var [b]long[/b] $28<<6
wait_var [b]long[/b]
[b]fit[/b] 496
Kind regards,
Robot Freak
PRI beat
dira[noparse][[/noparse]22]~~ ' make pin output
repeat
!outa[noparse][[/noparse]22] ' toggle HIGH and LOW states
waitcnt(40_000_000 + cnt)
and for the ASM - look at the ASM for beginners thread in one of the stickes - there is a post by me starting it, and Beau has an excellent post or two on setting pins...!
James
I'll try what your version does, and I'll search for the example.
Thanks!
pin_true is 1<<22 and pin_false is also 1<<22, pin_false should be 0
your jmp :repeat should also be jmp #:repeat
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
{{ heartbeat_asm.spin }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR BYTE id PUB start id := cognew(@Beat,0) PUB stop if id == -1 abort cogstop(id) id := -1 DAT org 0 Beat mov dira, Pin 'Make Pin an output mov Time, cnt 'Move cnt value to variable Time add Time, Delay 'Add Delay to variable Time :loop waitcnt Time, Delay 'Wait until cnt reaches Time, ' then add Delay to variable Time xor outa, Pin 'Toggle the Pin state jmp #:loop 'Jump to begin of loop Pin long |< 22 'Set bit 22 of Pin to logic true Delay long 40_000_000 'Set variable Delay to 40_000_000 (1/2 sec) Time res 1 'Reserve space for the variable TimeEdit: fixed link
Post Edited (Ale) : 4/15/2008 8:46:53 AM GMT
Glad you got it working
James
