Writing to a file.
So I'm using the propeller chip to process data, etc, and I was wondering if anyone has a simple example on how to write a variable's stored data to a file.
Say I get the signal strength from an xBee wireless mote every second. How could I take that signal strength variable and write the strength line by line each time I receive a new value?
For example, in Python you open a file:
...to write the signal_strength variable on each line of a new file, leaving you with all your signal strengths written on one line after another.
So the idea is to have this file saved in the chip's memory (or wherever) and then I'd come and grab that file somehow at a later time. If this is even possible, how could I do it in Spin?
Thanks a lot!
Post Edited (Intamin) : 4/14/2008 2:01:05 PM GMT
openedfile = open('newfile','w') 'Where newfile is just a random name 'Then you use Python's file class assigned to every newly opened file... while 1: signal_strength = blah blah blah 'What code is necessary to get the value every second openedfile.writeline(signal_strength) if not signal_strength: 'when there's no data left to be acquired, exit break
Thanks a lot!
Look in the Propeller Object Exchange for Basic I2C Drivers (for EEPROM use) and for SD Card FAT File System Drivers. Both can be included in your program and they come with examples. Look in the comments.
