3.3v devices
Hi
I want to do a project with a device (xport from lantronix) that has a 3.3V power . The high of an output is then of course also max 3.3V.(normal high is 2.4V)·Is that possible to directly connect it to an SX48 or do I need to adjust the high voltage in some way. If not neccesary I won't do it to spare some parts. If neccesary, how is the easiast way to do that. (xport is a tcp/ip to serial device. I want to use a bauterate of 9600. so any adjustmend on the line's need to be able to follow that speed).
Any sugestions?
Stef
Any sugestions?
Stef
-Paul
I'm going to give it a try. I'l connect him direkt to the sx48( the imput with a pull up 10K and the output direkt connected).
stef
I'l try that one also.
stef
Also, when working with a·SX running at 3.3V, ALWAYS remove the key from the target device before shutting off power to the key.
Trust me on this...
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
Post Edited (dkemppai) : 4/16/2008 1:27:32 AM GMT
http://www.sparkfun.com/commerce/present.php?p=Sensor-Interfacing
Joe
