There is a complete propeller sumobot somewhere on Parallax's site, can't find it now though.
here is the qti code
' main line code
VAR
long qti ' Stores Qtis object results
OBJ
qtis : "Qtis"
PUB main
qtis.start(16, 17,@qti )
case qti
%00, %01, %10: bot.go(bot#BACKWARD)
waitcnt(clkfreq/2 + cnt)
case qti
%00, %01: bot.go(bot#ROTATE_RIGHT)
%10: bot.go(bot#ROTATE_LEFT)
case qti
%00, %01, %10: waitcnt(clkfreq*2/3 + cnt)
' and the qti module
{{File: Qtis.spin
Demonstrates a way of reading QTI sensors repeatedly in a separate cog and
updating a variable in the parent cog during each update.
var
' Order matters for declarations of sPin, ePin, and address
' because of longmove in start method.
long sPin, ePin, address, qtiBits
long stack[noparse][[/noparse]30], cog
pub start(_sPin, _ePin, _address) : okay
{{ Starts the servos cog.
_sPin and _ePin are the endpoints of the contiguous group of QTI signal pins.
_address is the address of the variable that receives the QTI bit values.
Returns t/f for success.
longmove(@sPin, @_sPin, 3)
okay := cog := cognew(qtis, @stack) + 1
if okay
okay := @qtiBits
pub stop
'' Stop servos object and free the cog
if cog
cogstop(cog~ - 1)
pri qtis
{{This method repeatedly measures the surface monitored by one or more QTI sensors
and stores the result in the parent object's variable (determined by _address in
the start method).}}
outa[noparse][[/noparse]ePin..sPin]~~
repeat
dira[noparse][[/noparse]sPin..ePin]~~
waitcnt(clkfreq/2000 + cnt)
qtiBits := ina[noparse][[/noparse]sPin..ePin]
long[noparse][[/noparse]address] := qtiBits
The 470Ω bias resistor is for a 5V design, so you should be supplying it with 5V to ensure proper operation. You may also want to put an additional 470Ω resistor on the red line to protect the Propeller pin.
Perry
Thanks a lot!
Is this fine, or do I have to use 5V with a resistor on the white pin?
Paul Baker
