Prop Magazine, April 2008
Well nobody else has started this so I thought that I would give it a try. Don't expect it to be as good as Fred's though (even though I stole some of his formatting).
If I miss anything or make a mistake leave a post in this thread and I'll fix it.
This version of the Prop Magazine is now finished (unless I’ve forgotten something or made a mistake :-) ). Who’s going to do the job for next month? I’ve attached the text file that I used to make it easier for you.
Prop Magazine
April 2008
___________________________
ramblings by the editor,
Well, this is the 3rd edition of Prop Magazine. It won’t be that long and it will be time for an anniversary. Speaking of anniversaries, this must be about the 2nd anniversary of the Propeller Chip (If someone knows the exact date can they drop a note in this thread please). So, I have decided to include some of the old posts in this edition. On a more recent note there have been a fair few object releases this month. Check out the new games, I2C slave, nice user interface on the Quad DRO and the others listed below.
The ESC was also this month and some of the people from Parallax were there. Check out their reports below. Also on show was the Coyote-1 and the danceBot.
history,
A miracle chip?
http://forums.parallax.com/showthread.php?p=572347
FullDuplexSerial is posted. Probably the most widely used object.
http://forums.parallax.com/showthread.php?p=573059
Some early notes about the propeller.
http://forums.parallax.com/showthread.php?p=574855
Propeller Guts· - Some early documentation. Still helpful although most things are now in the manual and data sheet.
http://forums.parallax.com/showthread.php?p=572669
Being April there were of course a couple of special threads. First up was the release of the Relleporp.
http://forums.parallax.com/showthread.php?p=719874
And secondly a hidden assembly instruction was found!
assembly, MUL details divulged. (w/commented code)
http://forums.parallax.com/showthread.php?p=719514
basics,
Request for programs to put in a kiosk program for ESC (with any luck they will release what they used, get the hint?)
http://forums.parallax.com/showthread.php?p=721104
http://forums.parallax.com/showthread.php?p=721107
Questions about how long it takes to start a cog and other ways of accomplishing things.
http://forums.parallax.com/showthread.php?p=721723
Sine wave output from the prop
http://forums.parallax.com/showthread.php?p=719289
Pre-fetch and self modifying code. Something to watch out for!
http://forums.parallax.com/showthread.php?p=719199
Some questions and answers on accessing bytes in larger variables.
http://forums.parallax.com/showthread.php?p=720989
Some general questions and answers about what the prop can do.
http://forums.parallax.com/showthread.php?p=722437
Getting data from one pin to another and a how to use the timers to do it.
http://forums.parallax.com/showthread.php?p=722805
Changing variables between long and byte.
http://forums.parallax.com/showthread.php?p=723720
basics and beyond,
A question about required crystal accuracy.
http://forums.parallax.com/showthread.php?p=719322
and more questions about crystals
http://forums.parallax.com/showthread.php?p=717643
http://forums.parallax.com/showthread.php?p=722736
What are the threshold voltages of the prop? This tells you for one prop.
http://forums.parallax.com/showthread.php?p=719164
Questions and answers about what can hang a cog
http://forums.parallax.com/showthread.php?p=719142
Another fried PLL and some hints from Paul about how prevent it happening.
http://forums.parallax.com/showthread.php?p=719773
Pops and clicks in audio and how to avoid them.
http://forums.parallax.com/showthread.php?p=719989
Tools and methods for fixing memory corruption problems.
http://forums.parallax.com/showthread.php?p=712258
Using the pos/neg edge detector timer modes.
http://forums.parallax.com/showthread.php?p=720777
Initial states for the c and z flags.
http://forums.parallax.com/showthread.php?p=721039
QTI sensor code is here.
http://forums.parallax.com/showthread.php?p=721868
What does the @ operator do in asm? Also a tip on the @@ operator.
http://forums.parallax.com/showthread.php?p=722559
Questions about graphics and VGA (again, hopefully some answers this time).
http://forums.parallax.com/showthread.php?p=722523
More discussion about high speed comms.
http://forums.parallax.com/showthread.php?p=722541
Problems with the CORDIC object.
http://forums.parallax.com/showthread.php?p=722185
Questions about SPIN speed and the interpreter.
http://forums.parallax.com/showthread.php?p=724169
advanced,·
Creative use of the object[noparse][[/noparse]x].method notation to solve some problems
http://forums.parallax.com/showthread.php?p=718743
Questions about queues and some examples
http://forums.parallax.com/showthread.php?p=720709
Discussions on loading new LMM cogs in ImageCraft C
http://forums.parallax.com/showthread.php?p=721243
Discussions about new features for the spin compiler.
http://forums.parallax.com/showthread.php?p=718414
Using the prop as an RF transmitter and receiver.
http://forums.parallax.com/showthread.php?p=719507
new programs and objects,
An I2C Slave driver is now available in spin and assembly thanks to hippy (who has a D'Oh moment while testing multiple slaves).
http://forums.parallax.com/showthread.php?p=721563
Distance and Bearings calculations object for the prop by Chuck.
http://forums.parallax.com/showthread.php?p=721455
Ymodem upload utility by Rayman. Upload files from your propeller to your PC!
http://forums.parallax.com/showthread.php?p=719452
High speed serial by Stephen.
http://forums.parallax.com/showthread.php?p=720623
Quad DRO by Richard. Useful if you have a mill/lathe or anything else you need measurement info for.
http://forums.parallax.com/showthread.php?p=720621
A pop3 email client for the prop that displays the message From: and Subject: fields on your TV.
http://obex.parallax.com/objects/259/
On prop development using a spin like syntax. Again thanks to hippy.
http://forums.parallax.com/showthread.php?p=722452
Steven finally finishes the XOR version of Graphics.spin including the ROM font.
http://forums.parallax.com/showthread.php?p=723027
PropBASH, a modded version of PropDOS that is more like BASH
http://forums.parallax.com/showthread.php?p=723170
VGA Text driver for ImageCraft C.
http://forums.parallax.com/showthread.php?p=724335
Post Edited (stevenmess2004) : 5/2/2008 9:29:24 AM GMT
Prop Magazine
April 2008
history,
A miracle chip?
basics,
basics and beyond,
advanced,·
games,
Maze Mania released for Demo board and Hydra. Written by tpw_man who is only 10!
http://forums.parallax.com/showthread.php?p=721726
Clickin' Collapser released for Demo board and Hydra.
http://forums.parallax.com/showthread.php?p=718710
Development of Boulderdash started.
http://forums.parallax.com/showthread.php?p=721591
hardware,
Some useful info if you are building a Hydra from scratch.
http://forums.parallax.com/showthread.php?p=721545
Questions about a fried eepoms. Now to figure out why...
http://forums.parallax.com/showthread.php?p=721553
Fun driving a LCD screen WITHOUT a controller.
http://forums.parallax.com/showthread.php?p=719885
Lots of commentts on using xBees.
http://forums.parallax.com/showthread.php?p=716535
Some different options for wireless communication between props.
http://forums.parallax.com/showthread.php?p=720319
Level shifting circuits for various things.
http://forums.parallax.com/showthread.php?p=721065
Some help if you are having trouble programming your prop.
http://forums.parallax.com/showthread.php?p=651731
Some suggestions on pullup resistors on i/o pins.
http://forums.parallax.com/showthread.php?p=720213
5V I2C ADC hooked up to a propeller.
Some questions about stepper motors.
http://forums.parallax.com/showthread.php?p=722498
Adding external ram.
http://forums.parallax.com/showthread.php?p=722825
Powering the Proto Board from 12V.
http://forums.parallax.com/showthread.php?p=721903
Over-clocking the prop.
http://forums.parallax.com/showthread.php?p=724020
Talk about hooking up a Nunchuck to a propeller.
http://forums.parallax.com/showthread.php?p=658475
images & displays,
Interfacing with EInk displays.
http://forums.parallax.com/showthread.php?p=721778
schedule,
The ESC is/was this month. Some reports from some of those who attended.
http://forums.parallax.com/showthread.php?p=723122
http://forums.parallax.com/showthread.php?p=722995
http://www.parallax.com/TopLevelMenu/Company/2008EmbeddedSystemsConference/tabid/640/Default.aspx
Weekly meetings are held on the #propeller irc channel at 8pm to 10pm East Australian time on Thursday nights.
outside apps,
A new chip by the developer of the Transputer. Not really related to the propeller but interesting anyway.
http://forums.parallax.com/showthread.php?p=722137
Parallax stuff,
The propeller gets a write up at embedded.com
http://forums.parallax.com/showthread.php?p=719239
Paul lets slip that there is a new 64 pin version of the Propeller in the works. No time frame yet though.
projects,
Propeller controlled MP3 player. Check it out!
http://forums.parallax.com/showthread.php?p=721404
Musical propellers. Or at least musical bells controlled by a propeller.
http://forums.parallax.com/showthread.php?p=719913
A new projects list by OldBitCollector. Check it out!
http://forums.parallax.com/showthread.php?p=722100
More propellers in industrial apps. A propeller job display.
http://forums.parallax.com/showthread.php?p=722531
An 8x8 LED display driven by a propeller. Complete with uTube video.
http://forums.parallax.com/showthread.php?p=723069
adverts,
LB SMT is now open. They do surface mount soldering if you are scared to do it yourself.
http://www.lil-brother.com/
ImageCraft C pre-release special pricing.
http://forums.parallax.com/showthread.php?p=720130
ImageCraft C now in beta!
http://forums.parallax.com/showthread.php?p=722470
next month,
Prop Magazine needs an editor for next month. If you start on the first day of the month it will be a lot easier than starting on the last day! I’ll post the file I used for this month when its finished so that you don’t have to go through all the formatting again. A hint here is to just keep everything in a formatted text file and then copy the entire thing into the WYSIWYG editor (only works on IE unless you trick it).
Post Edited (stevenmess2004) : 5/2/2008 9:32:44 AM GMT
Graham
then highlighted it, clicked on the color, the size 6, bold,·and then on the middle text format in the Standard Form.
As for the url stuff, I didn't bother with a bracket arguments at all. I just managed it with a flat text file which is simply pasted after this paragraph. See the attached file for a comparison.
______________________________________
Gotcha,
________________________________________
references,
basics,
Prefetch impacts self-modifying code (w/link to deSilva asm tutorial)
Can a cog get stuck waiting?
byte basics
basics and beyond,
audio: pops at start and stop of wav file
debugging programs, best practices (divide and conquer)
on negative edge counting (counter setups)
advanced,
on queues
gps: conversions, ddmm.mmmm to dd.dddd, radians. (link to Circuit Cellar)
http://forums.parallax.com/showthread.php?p=721021
objects,
programming w/ solder,
innards,
Parallax stuff,
embedded props get a write up.
propplug logo up on protoboard
http://forums.parallax.com/showthread.php?p=720479
hardware,
on radio control,
signals between 3.6v and 5v chips
counters,
FSK, signal synthesis, decoding discussion.
demos,
Ymodem: upload data as [noparse][[/noparse]binary] file
circuitry,
circuit· design precautions and guidelines (how2 stop frying pll's)
use a 1K pull-up on prop plug whose cable will removed
http://forums.parallax.com/showthread.php?p=719485
more info inc fish's schematic: http://forums.parallax.com/showthread.php?p=651731
on pull-up resistors
adverts,
Imagecraft C 20% discount
Post Edited (Fred Hawkins) : 4/13/2008 10:12:56 PM GMT
I'll fix the rest of them up and include Fred's list after work today.
I may have to be a little more careful what I put in it or it will get too big but what could I have left out.
Actually I was getting a server error message when I tried to post it so I've split it into two parts which seems to solve the problem.
google's video introduction: http://www.youtube.com/watch?v=cII3TtewLsc
and what passes for their manual: http://www.google.com/support/toolbar/bin/answer.py?answer=79834&topic=13481
Post Edited (Fred Hawkins) : 5/12/2008 6:07:19 AM GMT
Everyone is welcome to add new sections and new links. No need to register or login to do so.
propeller.wikispaces.com/PropMag
Added : I've taken the May 2008 edition up to date as best I can see, and if there's anything missing please add it there - it's just as quick to do that as it is to post here !
I'll take on the job of doing the May 2008 edition but would be grateful if someone would be prepared to offer their services for June - I'll create a page template nearer the time - after that it's a very easy job of "write a line, cut 'n' paste a link".
Post Edited (hippy) : 5/12/2008 3:48:24 PM GMT
