how to connect a R/C plain reciever to a BS2? — Parallax Forums
BOB55BOB55 Posts: 36
edited 2008-09-04 22:46 in Robotics
Hi
How would you connect a R/C plain reciever to a BS2 so that servos connected to the BS2 would work with an airplane remote control?
BOB55
  • Tom CTom C Posts: 461
    edited 2008-04-13 00:09
    BOB55,
    You cannot use a plane (plain) RC (72MHz) with a ground device such as the BoeBot.
    Ground devices like the BoeBot require the use of a 75MHz transmitter/receiver combo.
    Just a thought.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
    edited 2008-04-13 00:47
    Bob, try not to post in more than one forum, it's confusing.
    - Stephen
  • DarkcornerDarkcorner Posts: 7
    edited 2008-09-04 02:28
    Hi you should use 75 MHz surface radio
    I am asking some of the same questions mainly to shut down to a safer mode when out of range
    edited 2008-09-04 13:31
    Have the output of the RC reciever go to an I/O pin of the BS2. Use "PULSIN" to read the I/O pin to get the "commanded" pulse-width.
    Hi all,
    Attached is a BS2 program that will allow an R/C combo to control the two BoeBot servos or anyother bot that uses a servo input to control its motors.
    I have successfully used this program to skid steer a four wheel rover using a pair of HB-25s.
    TCIII
