PROJECT: Maze Mania
This is a game that I ported to the Propeller from a very small game like this I made on my BS2. Basically, you go through a maze, but die when you hit a wall. It includes a built in level editor that prints out level data to the screen, and dumps it over the programming pins at 9600 baud. It is made for VGA. A better name would be appreciated. The Hydra version is untested. Can somebody test it for me?
Controls:
Arrow keys: Move character
F1: Go to level editor
Esc: Stop
**In editor**
Esc: Go back to game
Arrow Keys: Move character
3: Place enemy
F1: Dump level data
Characters:
$: You
#: Enemy/wall
@: Exit
The goal is to get to the exit without hitting any of the walls/enemies.
Not very high standard for the propeller, but I loved playing this game so I decided to port it.
EDIT: Forgot to attach the zip again.
EDIT 2: NOTE: You will need to set the serEnable constant to false to start up without a usb cable
Edit History
4/15/08: Added screenshot.
4/13/08: Added a Super Maze Mania Level Pack which contains all the levels that come with Maze Mania. Simply extract and copy folder contents to root of SD card.
Also added error message when SD card can't be mounted.
4/12/08: Added Super Maze Mania which can load levels off of an SD card and added a title screen.
Attached is both Demoboard and Hydra versions.
I am 1010, so be surprised!
Post Edited (tpw_man) : 4/20/2008 10:51:13 PM GMT
Controls:
Esc: Stop
**In editor**
3: Place enemy
F1: Dump level data
Characters:
$: You
#: Enemy/wall
@: Exit
Edit History
Or is it VGA only?
Share the knowledge: propeller.wikispaces.com
Lets make some music: www.andrewarsenault.com/hss
I attached the version of the AI-TV driver I mod'ed a while ago to allow for positioning.
use:
PUB Position( x, y )
Hope that helps!
--Andrew Arsenault.
Paul Baker
