Multiple power supplies decreasing battery life
I was just going through my "look this up" list that I add to whenever I see something I don't understand.
It seems that quite some time ago, somewhere, somehow, I ran accross info that said connecting the
grounds from multiple power supplies (a requirement to use more than one power supply if i understand
it correctly) will cause them to drain faster... thus killing a battery sooner than expected.
Since I have no idea where I saw this (most likely somewhere on the forum but the forum's search function
sucks) I have no way of further looking this info up.
Is this true? If so, why does it do this and is there any way to prevent it?
Hope you didn't read that, unchallenged, anywhere around here.
A better search means:
http://search.parallax.com
Post Edit -- "Lots" of linear regulators will effect battery life.· For instance, with a 12V battery pack, a 5V 1/2A [noparse][[/noparse]= 2 1/2W] output draws 1/2A from the 12V and·that is 6W total demand (not including current the regulators use in their own operation, small comparatively, but still additive.)· Do that twice and you start to get the point.·
But, that's not the same as joining circuits powered by one battery pack with those powered by another, by making their returns common.
Post Edited (PJ Allen) : 4/11/2008 12:36:17 PM GMT
Would there be anything additional to wiring all supplies to the same ground? (not completely clear on the use of the word "solid")
-thanks
A "Strong" connection would be one where lugs were firmly crimped onto the ground wires, and the lugs all screwed together firmly (assuming you're using a screw-terminal barrier strip or something).
It's possible to twist all the ground wires tightly together, solder the wires together, then cover the connection with heat shrink. In this case, you have to be careful that the wires don't 'shift' while the solder is cooling.
Tracy Allen
www.emesystems.com
