Serial Repeating — Parallax Forums
Serial Repeating
LanceRLanceR Posts: 8
edited 2008-04-12 04:02 in General Discussion
I'm trying to just parrot out the serial information (in at TTL and out at CMOS) and detecting and managing 4 buttons.· When I connected the GPS device to the serial out directly, it properly is showing at 4800 in hyperterminal.· I see the NEMA codes
But when going through this code, I'm getting gibberish.
Suggestions?
Thanks ahead of time.
Lance
'·· File...... LANCEGPS.SXB
'·· Author.... Lance Rasmussen
'·· E-mail.... lance@lance.ws
'·· Started...
'·· Updated... 10 APR 2008
' Program Description
' Device Settings
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "KEYPAD"
' IO Pins
'RC7Unused PIN RC.7 OUTPUT·
'RC6Unused PIN RC.6 OUTPUT·
'RC5Unused PIN RC.5 OUTPUT·
'RC4Unused PIN RC.4 OUTPUT·
RC7Unused· ·PIN ·RC.7 ·OUTPUT
NShutter ·PIN ·RC.6 ·OUTPUT PULLUP
RC5Unused· ·PIN ·RC.5 ·OUTPUT
NMeter ··PIN ·RC.4 ·OUTPUT PULLUP
KeyD· ··PIN ·RC.2 ·INPUT ·SCHMITT ·PULLUP······ ' Remote receiver D
KeyC· ··PIN ·RC.1 ·INPUT ·SCHMITT ·PULLUP······ ' Remote receiver C
KeyB· ··PIN ·RC.3 ·INPUT ·SCHMITT ·PULLUP······ ' Remote receiver B
KeyA· ··PIN ·RC.0 ·INPUT ·SCHMITT ·PULLUP······ ' Remote receiver A
RB7Unused ·PIN ·RB.7 ·OUTPUT ·PULLUP
RB6Unused ·PIN ·RB.6 ·OUTPUT ·PULLUP
RB5Unused ·PIN ·RB.5 ·OUTPUT ·PULLUP
RB4Unused ·PIN ·RB.4 ·OUTPUT ·PULLUP
RB3Unused ·PIN ·RB.3 ·OUTPUT ·PULLUP
RB2Unused ·PIN ·RB.2 ·OUTPUT ·PULLUP
'RB1Unused ·PIN ·RB.1 ·OUTPUT ·PULLUP
'RB0Unused ·PIN ·RB.0 ·OUTPUT ·PULLUP
TX··PIN·RB.1·OUTPUT· ··' Serial out at 4800
RX··PIN·RB.0·INPUT·········· ·' from GPS
RAUnused PIN RA OUTPUT
' Constants
Yes············ CON···· 0······················ ' active low input
No············· CON···· 1
Pressed······ ·CON···· 1
GpsBaud··CON·"T4800"··' to/from GPS module
' Variables
tmpW1·········· VAR···· Word
tmpB0··VAR·Byte···' subroutine vars
temp1··VAR·Byte···' subroutine vars
temp2··VAR·Byte···' subroutine vars
temp3··VAR·Byte···' subroutine vars
char··VAR·Byte···' vars
· PROGRAM Start
' Subroutine Declarations
·DELAY·········· SUB···· 1, 2··················· ' delay in milliseconds
·GPSRX·· SUB· ···' get byte from GPS
·GPSTX·· SUB· 1···' send byte from GPS
' Program Code
Start:
RA = 0
RB = %00000011
RC = %00000000
NMeter = No
NShutter = No
Main:
· GPSRX·····'
· IF KeyA = Pressed then
··· DO
····· GPSRX·····'
··· LOOP UNTIL KeyA <> Pressed
··· NMeter = Yes
····· GPSRX·····'
··· PAUSE 200
····· GPSRX·····'
··· NShutter = Yes
··· PAUSE 300
··· NShutter = No
··· NMeter = No
· ENDIF
· IF KeyB = Pressed then
··· DO
····· GPSRX·····'
··· LOOP UNTIL KeyB <> Pressed
··· PAUSE 10000
··· NMeter = Yes
····· GPSRX·····'
··· PAUSE 200
····· GPSRX·····'
··· NShutter = Yes
··· PAUSE 300
··· NShutter = No
··· NMeter = No
· ENDIF
· IF KeyC = Pressed then
··· DO
····· GPSRX·····'
··· LOOP UNTIL KeyC <> Pressed
··· NMeter = Yes
····· GPSRX·····'
··· PAUSE 200
····· GPSRX·····'
··· NShutter = Yes
··· PAUSE 4000
··· NShutter = No
··· NMeter = No
· ENDIF
· IF KeyD = Pressed then
··· DO
····· GPSRX·····'
··· LOOP UNTIL KeyD <> Pressed
··· PAUSE 3000
····· GPSRX·····'
··· NMeter = Yes
··· PAUSE 200
····· GPSRX·····'
··· NShutter = Yes
··· PAUSE 200
··· NShutter = No
··· NMeter = No
· ENDIF
· GOTO Main
' Subroutine Code
' Use: DELAY ms
' -- 'ms' is delay in milliseconds, 1 - 65535
DELAY:
· IF __PARAMCNT = 1 THEN
··· tmpW1 = __PARAM1··························· ' save byte value
· ELSE
··· tmpW1 = __WPARAM12························· ' save word value
· ENDIF
· PAUSE tmpW1
· RETURN
' Use: theByte = GPSRX
GPSRX:
· SERIN RX, GpsBaud, temp1···' get byte from 406a
· SEROUT TX, GpsBaud, temp1···' repeat·byte out to serial output
RETURN
GPSTX:
'· SEROUT TX, GpsBaud, __PARAM1···'·Send byte·to serial output
RETURN
' User Data
  • BeanBean Posts: 8,129
    edited 2008-04-11 11:48
    Lance,
    You cannot use the internal oscillator to do serial communications. It is not accurate enough.
    Also you are going to miss incoming data while you are sending data.
    Bean.
    Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
    www.iElectronicDesigns.com
  • LanceRLanceR Posts: 8
    edited 2008-04-11 17:27
    So if I put in a 20 mhz resonator in, without code changes, my code should work?
    edited 2008-04-11 17:59
    Also, would it be better to put this in as an Interrupt? I'm not quite sure how to set the interupt based on serial.
  • Shawn LoweShawn Lowe Posts: 635
    edited 2008-04-11 22:07
    no, you would have to put in a 4 mhz resonator for you code to work, or you can put in a 20 mhz and change your freq=20_000_000 line
    Shawn Lowe
    Maybe I should have waited to do that......
    I put a 20 mhz resonator. The speed seems to improve what is going to Hyperterminal, but still isn't the correct output.
    When I hook the GPS output to the serial out, I do get correct data (4800 8n1) but it doesn't seem to work going out of my program.
