Trying to write a class project in java but only half way thru intro to java !!!
programs will not compilied
I am using the javelin board, modifing the DS1620 program for a student project.
I had no trouble in changing the parallax code Program listing 4.6 simple DS1620 BUT
When I try to change it as the Java teacher would want: Create a class that doesnot have a main but has methods. Then create a client program to run the object, this one has a main, neither program will compilied.
I have both the class program call TP1.java and the client program TP1Client.java in the same directory.
public class TP1Class {
··· public static void main() {
········· TP1 tempProsStation = new TP1(74,1,10,true,true,true,true);
········· tempProsStation.tPRun(false);
········ } //end main
· } //end class TP1Client
the error message:
····· [noparse][[/noparse]Java Error] TP1Client.java(0): Warning: "c:\document_and_Settings\Student\capstone_jan_2008\Paul\TP" is either not a valid zip file or it contains a zip file comment. if it contains a comment, rezip it without a comment.
····· [noparse][[/noparse]Java Error} TP1Client.java(5) Error type TP1 was not found
···· [noparse][[/noparse]Java Error] TP1Client.java(5) Error no match was found for constructor.etc
the constructor has parameters int, int, int, boolean,boolean,boolean,boolean
I thought the problem is something to do with creating a package. Advance topic
also I added the path to the [noparse][[/noparse]options] classpath ...;c:\document_and_Settings\Student\capstone_jan_2008\Paul\TP· That's the directory that has the two programs
finally I tried in the TP1 program adding befor the import
package document_and_Settings.Student.capstone_jan_2008.Paul.TP ( I hade to put the underscore in
no luck
HELP
Paul cognig@aol.com
the error message:
no luck
HELP
Paul cognig@aol.com
to classpath and have a folder TP inside folder Paul,
then you should use
package TP;
and
import TP.*;
This is analogue to:
The standard classpath holds c:\program files\Parallax Inc\Javelin Stamp IDE\lib
which holds a folder stamp which holds a folder core.
So you use
import stamp.core.*;
regards peter
