Nubie question
I have a remote device that outputs 5v as long as the remote button is held.· There's 4 buttons.
For the moment, I'm simply trying to trip an led on for each button while its pressed to know its being pressed.· I split off the output of the buttons to the SX to go to another set of LED's to know the remote is actually firing ok.· I only really programmed for one button just to see what was going on.
The LED's from direct, fire great.· The SX, however, doesn't seem to fire them properly.·· Script as follow.
Input/Suggestions welcome.
' Program Description
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
ID············· "KEYPAD"
' IO Pins
KeyA··········· VAR···· RC.0··················· ' Remote receiver A
KeyB··········· VAR···· RC.1··················· ' Remote receiver B
KeyC··········· VAR···· RC.2··················· ' Remote receiver C
KeyD··········· VAR···· RC.3··················· ' Remote receiver D
PLP_Keys······· VAR···· PLP_C
LED9··VAR ·RC.7
LED8··VAR ·RC.6
' Constants
Yes············ CON···· 0······················ ' active low input
No············· CON···· 1
' Variables
theKey········· VAR···· Byte··················· ' from keypad, 0 - 16
tmpB1·········· VAR···· Byte··················· ' subroutine work vars
tmpB2·········· VAR···· Byte
tmpW1·········· VAR···· Word
· PROGRAM Start
' Subroutine Declarations
GET_KEY········ SUB···· 0······················ ' get key from pad
DELAY·········· SUB···· 1, 2··················· ' delay in milliseconds
' Program Code
Start:
INPUT RC = %00001111
LVL_C = %00001111
ST_C = %00001111
'PLP_C = %00001111
OUTPUT LED9
OUTPUT LED8
LOW LED9
LOW LED8
Main:
· theKey = GET_KEY····························· ' get a key
· IF theKey > 0 THEN·················· ' was a key pressed?
··· HIGH LED9··
··· DELAY 100
··· LOW LED9··
· ELSE
··· HIGH LED8
··· DELAY 100
··· LOW LED8
· ENDIF
· GOTO Main
' Subroutine Code
' Use: aByte = GET_KEY
' -- scans keyboard and places key value into 'aByte'
GET_KEY:
· tmpB1 = 0···································· ' reset value
· KeyA = 1····································· ' activate·Remote
· KeyB = 1····································· ' activate Remote
· KeyC = 1····································· ' activate Remote
· KeyD = 1····································· ' activate Remote
· PLP_Keys = %00001111·························· ' pull-up input pins
· IF KeyA = Yes THEN
·TmpB1 = 1
· ENDIF
· IF KeyB = Yes THEN
·TmpB1 = 2
· ENDIF
· IF KeyC = Yes THEN
· ·TmpB1 = 3
· ENDIF
· IF KeyD = Yes THEN
· ·TmpB1 = 4
· ENDIF
·RETURN tmpB1
' Use: DELAY ms
' -- 'ms' is delay in milliseconds, 1 - 65535
DELAY:
· IF __PARAMCNT = 1 THEN
··· tmpW1 = __PARAM1··························· ' save byte value
· ELSE
··· tmpW1 = __WPARAM12························· ' save word value
· ENDIF
· PAUSE tmpW1
· RETURN
' User Data
' Device Settings
' IO Pins
LED9··VAR ·RC.7
LED8··VAR ·RC.6
' Constants
' Variables
· PROGRAM Start
' Program Code
Start:
LVL_C = %00001111
ST_C = %00001111
'PLP_C = %00001111
OUTPUT LED9
OUTPUT LED8
LOW LED9
LOW LED8
Main:
··· HIGH LED9··
··· DELAY 100
··· LOW LED9··
· ELSE
··· HIGH LED8
··· DELAY 100
··· LOW LED8
· ENDIF
· GOTO Main
' Subroutine Code
GET_KEY:
·TmpB1 = 1
· ENDIF
·TmpB1 = 2
· ENDIF
· ·TmpB1 = 3
· ENDIF
· ·TmpB1 = 4
· ENDIF
·RETURN tmpB1
' Use: DELAY ms
DELAY:
· ELSE
· ENDIF
· PAUSE tmpW1
· RETURN
' User Data
· I would suggest using PIN instead of VAR when defining the SX pin aliases.
· Try something like this:
Bean
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
I'll give that a whirl!
What I'm doing is (I think) pretty simple.
Two things:
1) Manage the buttons from the remote to do things, which the original question was.
2)·Having serial data at 4800 baud come in at TTL (GPS) and then passed right back out on another pin at CMOS level. No manipulation of the data.·· I may, down the road, grab the data to show on a display, but priority at the moment is to essentially use the SX instead of a Max222 / Level converter, etc.
I know there will be a miliseconds of delay from the GPS in to back out.· But that's livable.
Is that something feasable and anything that you can point me to assist?
Lance
