Terry Hitts EL1883 Circuit
Hey guys was looking for a tiny bit of help or insight...
Ive just been getting into propellers and i coded up a nice osd with horizon and waypoint graphics etc.
I·was protoing up a little osd based on terry hitts schematic found·at the top of· his great sample spin files. I didnt quite pull it off.
I replaed the bat54s with switching diodes 1n1478's but·i dont·even know if that was the right move. Im pretty sure i got the rest of the diagram all right but just not getting a proper sync. It looks like its nearly·working but again sync seems off. I·get a bunch of white horizontal lines that look like there trying to make up the demo text.
I know this isnt much to go off but any tips from anyone who has built the simple circuit using a El1883. Im pretty new to the electronics side. Ive researched a bunch on video signals etc and get the general idea· but the tech side is still well over my head.
Thanks a ton in advance..
Jesse <--- Newb
Jesse <--- Newb
· I don't think using different diodes would matter much.
· Does it work when not doing overlay ? (I assume you are are using the HC-OSD firmware too).
· Do you have the filter cap and resistor on the EL1883 circuit ?
· Do you have an oscilloscope to look at the EL1883 output ?
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
The only times I have had problems with the circuit is with certain combinations of video source and my crappy B/W TV. If the source was not quite strong enough the TV would suck down the signal so that the sync separator would not function properly.
Perry
no·scope here [noparse]:([/noparse]
yep got the filter caps in place
dont think it was working without an input either fyi.
When i get home I'll try take a screenshot of output to see if it gives a better idea of what could be wrong. ·Yep your firmware. If i dont get anything from there ill build one more circuit from scratch to check for any·errors.
And just to double check im only using 5 pins of the el correct?
Thanks again
Jesse
-Marcus
I should probably mention that what I'm using is http://forums.parallax.com/showthread.php?p=635949
Revision 12 http://forums.parallax.com/attachment.php?attachmentid=46843
Post Edited (MarcusG) : 4/11/2008 5:05:05 PM GMT
This is the 3rd time i built it very carefully [noparse]:)[/noparse]
I·just tripple checked everything with a multimeter etc. all seems ok.
all 3 times ive had the exact same result which is when running HITT_Video_Overlay_018 i get some white lines nearly but not quite synced up on the left of my screen.
This is with no video input just output only.
Im thinking the only thing it could be is the diodes however ive tried· various switching diodes the final build here is using 1n4148's·
Here is a couple photos of the output
hrm yeah im at a tottal loss tho at what to try next.
Don't give up on this excellent design. I also built this circuit using a National Semiconductors LM1881 and IN4148 diodes as substitutes. It does work very nicely.
Just a couple of questions that might enable you to get this project fully working: -
1. You say your using an EL1883, did you mount this SMD part on a carrier board? or have you produced your own PCB?
2. Could you post a picture of the setup using?
3. No changes to the supplied Firmware? (realise your using this for the basis of your own project later on)
I made a couple of changes to the version that I built, I made R3 680K 1% metal film, also added a 0.1uf cap in parallel to ground.
Changed C9 to 560pf. I never touched the Chroma filter components, or had to pull capacitors out of circuit.
Have you checked yet again that you have the correct values for R5,R6,R7 ?
Looking on the brightside at least your getting some video generation from the project already, now is just debug time.
Regards
Mike.
When I accidentally started the OSD module alone I got a similar display.
Are you starting the whole application or just the video driver?
Perry
what is·the procedure you run to get it to work.
in the CON
area add
in mainline PUB area
added before the
This way many demo board programs can be adapted to Hitt's OSD or other set of video pins
etchNsketch is a good exanple
Perry
P.S.
this alone does not do overlays !!!
Post Edited (Perry) : 5/10/2008 3:00:08 PM GMT
i build a Hitt-OSD (with 1881, no sync-problems) too, and it works fine when generate graphics with colorwidth(1,0) / white .
Now i want to make a black frame around my "white graphics" using colorwidth(2,3). The only "black" i see is a grey shadow.
(Same problem when try to generate black graphics only)
Anyone an idea to solve this problem ?
Tharkun
P.S. When bypassing the diode (at pin18) with a resistor (approx.1K), the shadow changes to black, but this not the optimal solution, is it ?
P.P.S. Thanks to Terry Hitt for this amazing OSD.
Post Edited (Tharkun) : 10/5/2008 6:10:22 PM GMT
