Combining strings
I've scoured the manual, tried and tried. with no luck. Can some one tell me the command or how to combing strings.
I want to read some variables, and combine them as one long string. I was able to do this in Pbasic (going from memory) by: x = "hello_" + "world"
but if I do that with spin it seems to add the numeric values of the 2 and I only get weird symbols.
do I need to write each variable to memory and then read the whole memory area as one string?
I'm stuck. any help would be appreciated.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
DGSwaner
Paul Baker
DGSwaner
Post Edited (Dgswaner) : 4/10/2008 4:39:36 AM GMT
propeller.wikispaces.com/Strings
Example call:
var byte buffer[noparse][[/noparse]80] pub concatStr(@buffer,string("hiya-"),string("toots"))Concatenation routine
pub concatStr(dest,s1,s2) '' Concatenates two strings and stores the result in 'dest' bytemove(dest,s1,strsize(s1)) bytemove(dest+strsize(s1),s2,strsize(s2))-Chuck-
