Perhaps Basic Stamp routine (code) for Sensirion sensor have an error.
Hi
How can I know if the Parallax routine
is working.
I ask this because I have four different sensors
from differents brands and the Parallax sensirion give me always
15% less humidity than the others.
Of course if I change the Basic Stamp routine (or code)
adding 15% to the routine the problem disappears.
But then, it seems that the problem is not the sensirion sensor,
it is the Parallax routine or code.
Do you have information ?
Thanks, Joe
is working.
Thanks, Joe
I would see if you can find a HVAC guy and try your sensors out.
Good luck.
The more I look for common sense in the world...
the more·I·find how un-common it is.
