PE lab: Objects-EnterAndDisplayValues.spin
Hello
I am working my way thru the PE Lab: Objects and I am having some problems with EnterAndDisplayValues.spin
I can't get it to send the values back to the Hyperterminal.
I just used "PropTerminal" and I could get it to display the values, but I couldn't see what I was typing (no echo).
Thanks for any help
Charlie
Thanks for any help
Charlie
I couldn't get echo on the PropTerminal software. that someone wrote for the Propeller. It works pretty well, other than I can't find where you would enable an echo for it.
Charlie
I got the echo of my typing to work, but the Propeller still does not return· anything, no Hex, Bin or Dec values
This problem·is with the Windows Hyperterminal
Charlie
Paul Baker
there are a lot of reasons THINKABLE why it does not work.
Please attach your COMPLETE code.
This is the fastest way to help you
Otherwise this will be a ask-back-tiny-answer PING-PONG game
about 50 turnovers until the REAL reason is found
best regards
Stefan
I didn't have connection right "No Flow Control"
Thanks again
Charlie
