AppBee problem
I soldered up the boards, slapped on the XBees, hooked up the PropPlug, made sure it installed right, ran X-CTU, selected USB Serial Port (COM 6), and it doens't see the modem.
PC issues aren't possible, trust me.· What could it be?· Bad PCB parts?· Bad XBee?· Bad soldering job?
Looking for ideas cuz so far I can't think of anything.· Checked continuity on all the pins of the components, the signals propogate.· If I check the Enable API box, I get something but no device info.
Help!
Help!
The PropPlug is the right one, I found out from Martin. Could reversing the diode polarity cause this? It's the only thing I can think of.
It's the AppBee-SIP too, forgot to mention.
You can jumper between the AppMod header and the BS1 Project Board headers. It certainly would let you test things. You probably would have problems with the default Baud setting. I think it's 9600 Baud and the BS1 only speaks 2400 Baud (and slower).
I meant the RX/TX LEDs. Maybe they are reversed. Unfortunately I didn't solder all of them, so they might be wrong.
Because of the baud rate, I can't communicate from the BS1 to the AppBee cuz it's not configured yet.
Problem now is communication. My receiving program is running on a BS1, which offers no timeout option for the serin command.
How do I just grab packets from the serial input continuously and send them out of the serial output to a Pink?
I tried but it's stuck at the serin command.
SYMBOL RX = 0 ' Receive Pin
SYMBOL TX = 2 ' Transmit Pin
SYMBOL RFin = W3
Main:
SERIN RX, T2400, #RFin ' Accept and view as character
DEBUG "nodeInfo = ", #RFin, CR
GOTO Main
END
All I need to do is grab whatever is coming into the serial input and toss it to the Pink through the serial output.
' {$STAMP BS1}
' {$PBASIC 1.0}
[noparse][[/noparse] I/O Definitions ]
SYMBOL Ping = 7
SYMBOL TX = 2
SYMBOL RX = 0
SYMBOL SLP = 4
SYMBOL RTS = 6
[noparse][[/noparse] Constants ]
SYMBOL Trigger = 1 ' 10 uS trigger pulse
SYMBOL Scale = 10 ' raw x 10.00 = uS
SYMBOL RawToIn = 889 ' 1 / 73.746 (with **)
SYMBOL IsHigh = 1 ' for PULSOUT
SYMBOL IsLow = 0
[noparse][[/noparse] Variables ]
SYMBOL rawDist = W1 ' raw measurement
SYMBOL inches = W2 ' inches conversion
SYMBOL nodeInfo = W3 ' node presence
[noparse][[/noparse] Program Code ]
Main:
PAUSE 2000
HIGH SLP ' Put XBee to sleep
' SLEEP 15 ' Put BS2 to sleep for approx 15 seconds
GOSUB Get_Sonar ' get sensor value
inches = rawDist ** RawToIn ' convert to inches
DEBUG CLS ' report
DEBUG "Time (uS)..... ", #rawDist, CR
DEBUG "Inches........ ", #inches, CR
nodeInfo = 1000
nodeInfo = nodeInfo + inches
IF nodeInfo > 1022 OR nodeInfo < 1002 THEN Main
LOW SLP ' Wake XBee
PAUSE 10 ' Give XBee time to stretch and yawn
SEROUT TX, T2400, (#nodeInfo) ' Transmit value
PAUSE 10
DEBUG "Node........ ", #nodeInfo, CR
GOTO MAIN
END
[noparse][[/noparse] Subroutines ]
Get_Sonar:
LOW Ping ' make trigger 0-1-0
PULSOUT Ping, Trigger ' activate sensor
PULSIN Ping, IsHigh, rawDist ' measure echo pulse
rawDist = rawDist * Scale ' convert to uS
rawDist = rawDist / 2 ' remove return trip
RETURN
It's sending through XBee to the previous code on a receiver module. All are BS1 project boards.
